Computers & Internet Logo
Peggy Roe Posted on Nov 18, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lenova idea pad 300... after using mouse to play a game I can't move curser on the pad
NOEL
Level 3:
Top Expert:
  • The Master 8,606 Answers
  • Posted on Nov 18, 2017
NOEL
The Master
Level 3:
Top Expert:
Answers
8606
Questions
18
Helped
2318894
Points
68630
5 Related Answers
Anonymous
  • 35 Answers
  • Posted on Sep 22, 2007
SOURCE: Razer Death Adder still can move when lift it up from pad
Could there be some dust inside the laser eye or something else. On what surface are you using it. Try it on a blank piece of paper
egadgetguy
Ken Williams
  • 263 Answers
  • Posted on Aug 14, 2008
SOURCE: Optical Wireless mouse does not connect
uninstall blue tooth software and start over from scratch.
Anonymous
  • 341 Answers
  • Posted on Dec 09, 2008
SOURCE: mouse is sticking and not moving
With the computer on try to unplug it from the computer, wait a few seconds and plug it back in. Many times this will do it. If not, unplug it and then plug it into a different usb port. The computer will think it is a new device and reinstall the drivers for it in that port. It's a simple solution ,but works many times. Good kuck.
Anonymous
  • 125 Answers
  • Posted on May 06, 2009
SOURCE: moves erradically on screen
Change the battery. then re-sync the mouse
Anonymous
  • Posted on May 24, 2009
SOURCE: turning off the mouse pad on Lenovo 300 n500
You have a button just to do that simle task, its un the upper right side and it has a touchpad on it, press it, looks like a display but its a button :)
One image worth 1000 words:
http://www-307.ibm.com/pc/support/site.wss/71738_touchpad.gif
Complete guide found in LENOVO support:
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-71738
Connects and clicks just doesnt move the curser
I presume you can see the motion sensing red LED or laser beam shining under the mouse. If not, that has gone bad, and it would probably be more economical to replace the mouse than to attempt a repair.
If the light is on under the mouse, try cleaning the lenses (both LED and photoreceptor) with a cotton swab dampened with isopropyl alcohol (rubbing alcohol). Don't scrub, just wipe the optics gently until clean.
Mouse doesnt work nicely when playing cross fire
no pad?
well it can only be
  1. no PAD or dirty pad or pads with patterns mouse hates
  2. bad mouse only gaming.
  3. bad mouse drivers.
  4. or setting wrong.
why not try the mouse on other PC same pad see if it acts wrong
then if works great the other PC is failing (software)
NO PC told
NO OS told at all
if PC is infected it runs slow or erratic.
if PC has bad hdd same. and lots more,
is only one game failing
is this your first gaming PC"
is this only in MP mode gamed or also SP mode,? both? what?
try a real gaming mouse
if internet is slow mp will be slow , or OMG the gaming server is slow, MP. HAPPPENNNNNNNNNNs
1helpful
Why wont the curser move on my computer
Go into the device manager and go through the list until you see the mouse, check box to the left and right click, if the pad is disabled enable it, be careful not choose the external mouse.
How do I unstick my curser. I have re-booted, shut off and restarted the computer. I can not get it to move at all but the curser will move if use external mouse
You should have two buttons either side of your power button,
one of which (the right hand side i believe) controls your wireless connection, and if pressed your notebook will not be able to pick any wireless connections up.
The left hand side button controls your touch-pad device, possibly you have pressed this button without realising and it has disabled your mouse. Simply hit it again to resume the function of the mouse.
2answers
New mouse , curser not moving properly
Are you using a mouse pad? At work I see this all the time. Sometimes the user is using a mouse pad that throws off the sensor on the mouse(if you're using one with a laser or optical sensor).
Try utilizing a new pad first and report back if that helps. Sorry, but its hard to identify the issue without more clarification.
Thank you.
Curser will not move
Hi and welcome to FixYa!
If you are using the touch pad and the cursor will not move, you may want to try and use a mouse. The touch pad on your computer may have worn out. If the mouse works, it may be your pad.
Please check to make sure that touch pad button is on. If the mouse will not move the cursor, your drivers may have been corrupted and you have to download new drivers after uninstalling the old one. Which one you download will depend on what type of computer you have.
Thank you for asking FixYa!
KittyTech
If you need further help, reach me via phone at https://www.6ya.com/expert/carolyn_427ff26936286336
When I boot my notebook up I can't move the curser, it is stuck on one person to sign on, the curser is not positioned on that persons name either.
TRy plugging in an external USB mouse. If the mouse is OK then the touch pad has failed.
Check the touch pad driver in the control panel then Device manager.
Hope this helps.
Mbj58 wheel mouse curser wants to go all over screen
Hi a. Have you tried another mouse and
b. Are you using a glossy or prismatic mouse mat? Try using a different one or a sheet of A4 and see if this fixes it
hope this helps Mark
Curser frozen
did u turn off ur touch pad.
did u check by useing an usb mouse
Mouse died
While using the mouse with the laptop you may use a proper mouse pad to avoid reoccurence
Top The Computers & Internet Experts
Alexander
vince
Steve Sweetleaf
Steve Sweetleaf
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
