Insignia IS-LCDTV32 32 in. Television Logo
Posted on Nov 23, 2007
Remote My comcast remote will not respond to the TV after trying several codes and talking with a Comcast remote.
  • Anonymous Feb 29, 2008
    same here...i have insignia lcd26a hdtv and my comcast remote doesn't respond know matter what codes i try
    help
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 10, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
522
Points
Insignia finally has a remote code finder on their website!!
http://www.insignia-products.com/universalcontrolcodes.aspx
A
Anonymous
Programing my xfinity remote
About 13,200 results (0.79 seconds) Search Results
    Can't program Comcast remote to Element TV - Comcast Help and ...
    forums.xfinity.com/.../XfinityTV...program-Comcast-remote...Element-T...
    Jun 6, 2011 - I have an Element 47" Class LCD 1080p 60Hz HDTV, ELGFT471. My remote is the Comcast Universal Remote - Red OK/Select Button.
    Comcast - what programing code to use with element tv find ...
    https://www.directly.com/.../comcast-what-programing-code-to-use-with-...
    what programing code to use with element tv find a code does not work ... Mymistake. ... Also found that Element has a remote update for some televisions.Missing: panel
    Element Tv Comcast Remote (Tut) - YouTube
    ? 3:19
    https://www.youtube.com/watch?v=ZDBr-hZN2AI
    Jan 20, 2010 - Uploaded by TopBreakX3
    The tut should be in your comcast remote paper help thing but heres the code if u cant see ... cant see clearly ( 10178 ) This is a vid on how to setup your comcast remote for your element lcd tv. ... Who cares program the Comcast remote already ... this was awesome,,,,my sisters tv is on the go now,,,thanx .Missing: panel
    Comcast Remote Codes for TV - Easy PC Tutorials
    www.easypctutorials.com > Comcast
My remote does not work
Remote Code for LCD Coby TV model TFTV2425 - Comcast Help and ...
forums.xfinity.com/t5/XfinityTV.../Remote...LCD-Coby-TV.../916553
Apr 14, 2011 - Remote Code for LCD Coby TV model TFTV2425 ... If your home entertainment device does not respond to the remote control after trying all of the codes listed for your ... I just changed to an hd box andcodes given by comcast did not work. Looked at my old remote notes and that is what I found and it works. Comcast DVR remote won't "select" an input from th...
May 26, 2011
Remote code for coby tvs
Feb 7, 2011
Comcast remote code for Coby tv/dvd
Mar 20, 2010
More results from forums.xfinity.com
Coby tv remote doesn t work Questions & Answers - Fixya
www.fixya.com > Forum > Tags > tv remote doesn t work
How do I get my Bravia #KDL-40S4100 remote to "talk" to a Comcast remote?
You might try posting your question on the Comcast help and support forum. Be very specific about what the model number is for your Comcast remote and TV remote. To be specific the remote "Talks" to the TV not the other way around. I personally find it easier to use both remotes because at best the Comcast remote cannot duplicate all the features of your TV remote.
here is the link to the forum. You will need to join and create a password etc. You will find a lot of help at the forum about every Comcast product TV, high speed internet, E-mail, security and so on.
http://forums.comcast.com/
Comcast remote codes for 233t-12
All the codes for the remote are in the user manual, if there is no code that works with the tv, then I'd recommend trying the code search feature, if there are no codes that the tv responds to, then the remote can not be used with that tv.
If you post me the model of your comcast remote I can look up the codes for you.
4helpful
Comcast Remote Codes for a RCA L32HD31R LCD TV Also Panasonic
Hi Attychase,
Comcast actually has several different remotes for their different set-top boxes and the remote codes aren't always the same. They list all of their current remote devices on the following page. If you click on view manual it will give you a list of remote codes.
http://www.comcast.com/corporate/customers/customer_support/remotes.html
Hope this helps.
Need codes for remote control access to go with Comcast hd adapter remote. Only 2 listed with remote from Comcast: #'s11723, 12066 Comcast remote will not control TV
If you look at the instruction under 'search for your codes' it will tell you how to scan all the code until you find the one that will work. Down load the manual here for your remote:
SEARCHING FOR YOUR CODE
brand, or if your brand is not listed at all,
try searching for your code.
For example, after trying all of the
codes for your TV, you still cannot get
the remote control to operate your TV,
then:
1. Turn on your TV.
2. On the remote control, press TV
once. Then press and hold Setup
until the TV key blinks twice, then
release Setup.
3. Enter 9 - 9 - 1. The TV key will
blink twice.
4. Aim the remote control at the the
TV and slowly alternate between
pressing Power and TV.
Stop when the TV turns off. A
working code has been found.
NOTE: In the search mode, the
remote control will send IR codes
from its library to the selected device,
starting with the most popular code
first.
5. Press Setup once to lock in the
code.The TV key will blink twice.
39helpful
3answers
Sharp TV (LC52D64U) remote control Comcast cable (DVR) box ?
I had the same problem with my remote. I would enter the code and there would be no response from the remote. I looked up the manual for the other comcast remote and the codes are 5 digits instead of 4. Try codes 10093 or 11602. The reason why there is no response from your remote is because it is waiting for you to enter the last digit of the code. Hope this helps.
25helpful
8answers
Program Comcast remote to operate Samsung 46"LCD
The answer depends whether its a Comcast DVR Remote or a regular one. The DVR codes are 4 digit -- the others are 5 digit. I got 0060 to work for my DVR remote.
65helpful
17answers
Remote Codes for new Sony Bravia
I plugged this code in and it worked:
10000
Good Luck
4helpful
7answers
Top Insignia Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
