SOURCE: my maytag bravo top loader washer is displaying a code of LF and
it meant "low flow" check water connecting lines. mine has the same problem.
SOURCE: Maytag Bravos washer leaks.
Either the valves are leaking themselves or tub is leaking. Most likely the water valves.
SOURCE: We just bought a Maytag Bravos washer. We were
it should be very tight if you look down the middle of the adjitator it should have a aloy screw that should be done up very tight
SOURCE: How reset clean washer reminder on Bravos washer
This is just a factory setting that reminds you to clean the washer to avoid that musty smell. You can buy tablets called Affresh or other similar cleaners for washing machines. They sell these items at Target, Walmart, Lowes and Home Depot. You can also substitue 1 Cup of Bleach in the washer. Then once you add whatever solution you have decided to clean it with you simply select the wash cycle on the machine called "Clean Washer with Affresh" Once you have done this the light should go out. You can also reset this indicator light by pushing the button next to the light that says Reset clean washer reminder. Hope this helps!! :)
SOURCE: maytag washer flashes f 51
You will need to replace the RPS sensor. There is a kit available that will update that washer to the current design. Here is the kit to order.
https://m.youtube.com/watch?v=iqA0vtEgRP...
