Can you tell me what part to replace? Picture is good.
SOURCE: what is the remote code
turn tv on
on remote
1. hit tv
2. hold down setup till it blinks twice(tv button light)
3.then press 991 wait till it blinks (tv button light)
4.press channel up slowly until tv turns off
5. once it turns off hit setup again
6. press the tv then power button and then see if tv turns on if not then you just missed the code(repeat)
SOURCE: Panasonic VIERA TC-L32C3 32-Inch 720p LCD HDTV
Hello, welcome to Fixya!
You didn't state any problem concerning this TV. What precisely is the problem with your Panasonic VIERA TC-L32C3 32-Inch 720p LCD HDT?
I look forward to your reply.
Regards.
SOURCE: i have a panasonic TC-P42C1 blinks 10 times no
main board not on power,dont suspect the power board//
SOURCE: panasonic plasma tv showing a blink code of 8 blinks what does this indicate
8 blinks Driver SOS 3 SS Board (SS energy recovery circuit) is faulty. If you wish to get more detail about this fault, check this link. Pull up older posts there.
Testimonial: "To Gopakumarg43 I thank you for taking the time to reply to my problem witha panasonic TH-42px70b with 8 blinks as the fault code I have found your sollution most helpful than you again Ralph Bouette"
when I bought the TV I brought it home and and plugged it in and it went to blinking after a few minutes I noticed the heat sink on the center of the power board in between the two other heat sinks was getting hot the service manual success blink code 1 as either a problem with the power board or the LCD panel any help in diagnosing the problem I would be grateful for thank you
