SOURCE: fax uf 590
Pull open the bottom of the operating panel just above the paper tray one inch 1". Clean the small scanner glass with alcohol, it's hard to see. It's just above the first rubber roller at the black base of the machine.
SOURCE: meter or counter reading
press function,7, monitor ,monitor, monitor, monitor (that's 4 times). Then press the star key. press 3 then the down arrow twice and then start. That should print a report showing the page count.
SOURCE: Need to set Panasonic UF 890 to print out confirmation of a sent
Press
Function 74
set
12
set
2 for always
set
stop
SOURCE: Panafax UF-550 Plain Paper Laser Fax: I have a Panasonic Panafax uf-550 and I need to kn...
press
function
74
set
12
set
set
stop
SOURCE: I have a Panasonic Panafax uf-550 and I need to kn...
Apparently, you can set it for the default condition or you
can set it for the current fax you are sending.
To set the default:
1. Press "Function" then "74" then "Set"
2. Press "12" then "Set"
3. Press "1" for OFF
Press "2" for ALWAYS
Press "3" for INCOMPLETE only
4. Press "Set"
5. Press "Stop"
If you want to over-ride the default for the current fax,
1. Press "Function" then "8"
2. Press "1" then "Set"
Press "2" for ON (always print out)
4. Press "SET
Thanks to FixinFax for the clue for the default setting.
Alex Cook
