To engage or disengage the drive motors: 1. Locate the manual freewheel levers at the front of the chair. See figure 5. 2. Push the levers down to engage the drive motors (drive mode). See figure 8. 3. Pull the levers upward to disengage the drive motors (freewheel mode). See figure 9.
If a lever is difficult to move in either direction, rock your power chair back and forth slightly. The lever should then move to the desired position Manual link below.
https://www.pridemobility.com/pdf/owners_manuals/us_jazzy/us_jazzy_select_7_om.pdf
SOURCE: We have a Jazzy 1113
The battery of the chair is dead. It will say its charged but then when you take it off it will die.
You have to replace the battery.
I had the same exact problem with my father.
SOURCE: My Jazzy won't move.
If your batteries are truly charge they should read around 24.5 VDC. And if the freewheel lever is engaged and you still have no movement your probably need to get into a service tech. Also check the circuit breaker on the chair.
SOURCE: the gear shifter handle moves but the van stays in park
there is a cable attached to your transmission that is actuated with that lever. the cable has come disconected or has broken. open your hood and look for cable on top of your transmission to see if it is worn.broken ect. helps to have somebody move lever while u locate it if you are not sure what you are looking for.
SOURCE: i have a quantum 600
Sounds like you need new batteries. Assuming that the chair is programmed for a faster speed and has gone faster in the past the most likely culprit is old or discharged batteries. The charger or plug may be at fault also. Also check that the charger is plugged in and the indicator lights of the charger are on.
SOURCE: chair was working. replaced batteries. now not
might be sleep mode try pushing the on/off button twice to get out of sleep mode Hope this helps
