Delayed trigger of camera shutter, and multi time lapse shots
SOURCE: how do you repair a sticky shutter
Clean the Affect area with Denatured Alcohol ,Once its clean ,Should work ok .Hope this Helps ttech
SOURCE: Can you switch a video from time lapse mode if it has already been shot?
If anyone can do this, it would take a video production expert that can pull the audio track off and then patch the audio and video track back together. This will require high tech equipment, and quite a bit of expertise to get the two tracks to match. My guess is that this could be done for about $100-200 depending on the expert's rate and actual amount of time they spend on it. Check your yellow pages or the internet for someone in your area that can do this type of video editing.
Good Luck
SOURCE: Delayed shutter
Here as in some other posts, you can try to RESET the firmware in the menus. Go through the menus and find where it says something like reset all.
What this does is to reset it back to factory settings.
Then set the options you like, and then try the camera again.
Check the diff. modes for the picture taking. See if the flash can be turned off.
SOURCE: Olympus 0M10 ..delayed shutter speed?
Be sure the mode knob at the top beside the wind lever, is set to Auto ( not B or Manual Adapter ). Then be sure your lens aperture is set to a lower number like 2 or 4. If this doesn't change things, it probably needs repair.
