SOURCE: Smeg Washing machine
This happened to us before and we had to actually reset the unit. I had to call the tech support and they walked me through the process.
SOURCE: error code 43 on F& P washing machine
The micro switch or the lever that activates it seems to have been the cause of the Error Code 43. Have re-seated the switch in its holder and ensured the activating (out of balance) lever is moving freely. The switch appears to be OK and now it is all re-assembled, the Error Code 43 is gone. Machine is operating normally again.
Out of Balance Switch was located below the right hand side of the computer board (module).
Rgdz John T
SOURCE: Panasonic workio DP-3530 error code E01-20
e1-20 means " laser unit horizontal problem" its ether your lsu is not connected or defection or you spc board is not connected or defective.
good luck
SOURCE: Rsio TR1510 Error Code E01
Yes Easy. Get out the Sylinder drum, switch off the machine: open a back cover' on a board press reset then switch on the machine while the drum is out; then insert the Sylinder Drum. the error should be gone.
CHIMUNTU
SOURCE: fix code error F8 in whirlpool washing machine
F8 is a board failure replace control board ( Also called ERC or clock )
