Question about Electrolux Ovens
My Electrolux double oven goes from "bake" to "warm oven " after about 1 hour. I try to use the other oven and it will go start to "warm oven"
  • Electrolux Master
  • 2,699 Answers
Is the bake element getting hot?when you put the oven on bake both the broil and bake elements come on,if just the broil element is getting hot it might take it an hour to heat up.you might just have a bad bake element,if the bake element isn't hidden does is turn red? if not it's not getting hot.
Posted on Nov 19, 2017
6ya staff
SOURCE:
Anonymous
  • 116 Answers
SOURCE: Double oven / convection not working
It is likely that the convection element is burned out and needs to be replaced. If all other functions are working then this is the place to start. Teh back panel inside of the oven can be removed by removing the 4 visible philips screws on it. The element should look smooth and round, if not then it needs to be replaced. Be sure to turn power off to the oven before replacing it. Remove the screws that fasten the element to the back wall and gently pull the element away from the wall an inch or so. the wires will be exposed and can be unclipped from the element do not let them fall inside of the back of the oven or you will have to remove the oven from the wall to get at the back panel. Install the new element in the reverse procedure. If the element looks good then it will have to be tested with a multimeter to verify that it is still good before proceeding to check the selector switch for burn marks.
Posted on Mar 11, 2007
Anonymous
SOURCE: Electrolux Icon Mystery issue
Check to be sure your racks are all slid in to the back. Are you getting a error code?
Posted on Dec 25, 2007
Master_Tech
Gary Davd
  • 770 Answers
SOURCE: Fan runs for hours after use
The fan is in place to cool the electronics it will run after the unit is off it is possible you have a bad sensor on the fan circuit leaving it to run too long
Posted on Apr 05, 2008
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: Electrolux double oven does not get hot
If it is a fan assisisted oven and the fan is still working, then you need a new oven element fitting.
Plz rate my solution.
Thanks.
Posted on Jan 11, 2009
Anonymous
SOURCE: Wolf Double Oven
I had the same problem with a Wolf L-Series double wall oven (Model DO30) and called for service (under extended warranty contract). The tech told me that the F1 error is a latch problem (you know the one that grabs and locks the door during self-clean cycles). He cleared the error using a series of "secret" button presses on the control panel and the problem cleared. Now, when it happens (which isn't very frequently), I do the same thing he did ... press "0" and "Temperature" for the oven causing the problem and hold them for about 5 seconds. The oven will ding and the display will show some diagnostics, including the error event. Press "Cook Time" and "Stop Time" while in this diagnostic mode to clear the error register, then press "Off". I've also tried to keep the area across the top of the oven opening clean (with a little degreaser), especially around the latch, and I've sprayed a bit of WD-40 into the latch periodically for lubrication and cleaning.
Posted on May 22, 2009
How to replace the lower, hidden bake element in the lower oven of an Electrolux Icon oven
You need a 1/4 or 1/16 mm. to take it out, they always have a simgle plug.
Nov 13, 2013 | Electrolux Ovens
My bottom oven ( non-confection) will not go on-it will just sat 100 degrees but won't get warm or hot. Top seems to be working fine. This started after I tried to use the self cleaning feature.
If broil and bake do not work on your bottom oven, it is probably your lower thermistor or control board. If the bake works but broil doesn't or broil works and bake doesn't, it is very likely your heating element. With an ohmmeter, the heating elements should be about 40 ohms. Much higher or lower signals a problem. If you suspect the control board is the problem, they can be repaired quickly and reliably at www.fixyourboard.com
Oct 11, 2010 | GE Profile JTP56 Electric Double Oven
Uneven rising & baking in convection oven
I repair commercial cooking equipment for a living. When a customer complains about uneven cooking the #1 thing that these manufacturers ask is..... are they turning (180*) the baking sheets half way thru the cook cycle. #2 are they staggering the pans front to back & side to side. It's kind of a pain but, works for the commercial ones.
Jul 24, 2009 | Amana AEW3530DD Electric Single Oven
GE P7 Wall oven model JK1905AV only gets warm....
I have a pair I'm trying to get rid of if you're interested.
Jul 15, 2009 | GE JKP50SH Electric Double Oven
RE: Double convection wall oven (GLEB30T8ABA) Need to use timed bake option
Connie,
Found the owners manual but it was worthless didn't have the control board information.
Found the control board and it used in quite a few other makes has same functions on all the units.
So here's my best answer not your unit but is the same control board..
Sure hope this helps!?
https://c.searspartsdirect.com/mmh/lis_pdf/OWNM/1201522L.pdf
Best to you.
Jan 28, 2018 | Frigidaire GLEB30T8A Electric Double Oven
EOU6330 grill doesn't heat-up all the time.
hi Step 1: Check the power cord, the plug, and the outlet. Then look for blown fuses or tripped circuit breakers at the main entrance panel or at a separate panel.
Step 2: If the range is receiving power, set the timer on the range to the MANUAL position.
Step 3: If the element still doesn't heat, turn off the power to the range and test it with a VOM set to the RX1 scale thank u................
Sep 11, 2008 | Electrolux EOU6330 Electric Double Oven
Dec 14, 2007 | Electrolux ICON Designer E30SO75ESS Oven
Ovens Logo
64 people viewed this question
Top Electrolux Ovens Experts
John Tripp
John Tripp
jdthefixer
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
