I switched off the breaker overnight but today when I turned on the breaker, the oven is still clicking, the fan is running and I can see a red light inside the area where the fan is. The error message says, in part, "unexpected door unlock". The door opens and closes fine. We tried starting a new self-clean to see if it would reset, but it didn't. Is this a cheap and easy fix or a nightmare? We've only had this a year and a half.
What was the error code?you should never self clean your oven before any big holidays,for reasons like this, if it takes out a part the part most likely will have to be ordered and the last day they take orders at my parts store is monday before thanksgiving so if it's your clock and you have to order it you might not have it for thanksgiving so hopefully you just have a bad latch assy. and you can get it fixed before the holiday,from what i've seen i will never self clean my oven,i use easy off and scrub it,the oven gets up to 1000 degrees and it damages the electronics in the oven.the clicking you hear could be the latch assy. unplug the oven.open the door and see if the hook part that locks into the door isn't jammed,i just went out tuesday to change a latch assy and that part was jammed,the rod that goes from the motor and to the door latch was hitting the metal part of the latch that bolts to the frame and i couldn't move the hook part or catch at all and the motor was clicking trying to move it,i had to lift the top of the stove,bend the body of the catch assy. so the rod could move freely and that fixed it.but using the self clean short lives the oven and it can damage the latch or the clock assy.send the error or just goggle it and it will tell you what it is.
https://www.searspartsdirect.com/model-n...
go here open pedestal and look at part 150 that's the latch assy. in your model.you can look at the clock assy. too or any other parts in this model hope this helps you out without the error code i'm just guessing from what i see in other ovens that have issues after self cleaning
SOURCE: oven door locked
First check to see if you activated the "child lock-out". See your manual to deactivate.
You could also try unplugging the unit, or trip the circuit breaker in your home which supplies power to the oven. Wait 5 minutes and turn power back on. This will reset the controls.
SOURCE: DCS double wall oven model WOSD 230 totally dead during first self clean
let me know if you don't get the solution... thanks
SOURCE: "door lock" light stays on and oven won't work
Same problems. When I removed the lock operating arm nothing happened. Motor is not operating. I've temporarily kluged it by tying the "unlock" (upper) switch circuit together and disconnecting one side of the power to the "locked" (lower) switch. At least we'll have an oven to use, but I'll have to come back and remove the lock motor assembly to find out what's really wrong.
BTW, if some knows those keyed-in service codes they could be useful.
SOURCE: whirlpool rbd275pdb double wall oven died during self clean
The first time we used our Whirlpool oven the same thing happened - no power and yet the circuit breaker was not blown. I called Whirlpool, and they sent out a technician to check it out as it was still under warranty. He said the temperature was off (too hot) by 20F - he adjusted. He also replaced the blower. What he did not tell me was that the thermal fuse had blown, and he replaced it - this was the REAL cause for the failure. I got the impression that he did not want to let me in on the secret. He did not note on the paperwork that he replaced the thermal fuse. Last week I decided to run the oven through the self-cleaning cycle (the oven is now 8-1/2 yrs old) - I don't believe that we cleaned the oven but a couple of times since the first time that it was "repaired." I used the default 3-1/2 hour setting. Everything appeared to be fine - the oven went through the cleaning cycle with no apparent problems. The display now read "cool down" - I went to bed thinking everything was okay. I got up the next morning only to find out that the power was out. I called Whirlpool and demanded that they repair the unit again as they clearly never fixed it correctly in the first place. They offered me 15% off on a new oven - WHOOPEE! I asked to speak with the supervisor - he did not budge either. I was upset, and I told him that I would NEVER purchase a Whirlpool appliance again! I decided to tear into the oven to see if I could detect anything wrong. I pulled out the front panel - everything looked okay. I then noticed the "thermal fuse" - I did not know what it was called at the time, but it looked familiar. I checked voltage on either side of the fuse and found the voltage to be zero on the downstream side of the fuse. I pulled it out and read the information on the device: Microtemp 110C. I called a local appliance repair shop - they told me that it would cost $50 to purchase a new fuse! I told them that seemed very high. I ended up stopping at Radio Shack. They have thermal fuses in various temperature and voltage ranges. I got a 144C 10A fuse and carefully soldered the connectors to it and replaced the protective plastic sleeve. I actually bypassed the thermal fuse in order to use the oven before I found the replacement fuse. While it is a good idea to have a protection device for the slim chance that an oven may malfunction by overheating, it is not a necessity for the functionality of the oven. Hopefully, the thermal fuse will not fail during my next attempt to self-clean the oven. I do have a concern about the 10 amp rating, but I'm sure that it will work fine.
SOURCE: Self-Clean oven fan will not turnoff and the door still locked
Have you tried to unpulg it and see if it unlocks
