The soap in the dishwasher lately has been found intact on dishes, in cups, in baby bottle nipples, everything. It is undissolved. We switched to gel, as the powder dishwasher soap was not dissolving - this does not seem to have fully solved the problem - the dishwasher runs, the soap container is open after the cycle, any ideas?
I have also had this problem before too and i would suggest that either your pump or drainage tube is blocked. It could also be a solinoid failure in your water intake valve if connected to hot water tap or fuse in thermostat if internally heated. Most dishwashers have service codes displayed by lights/flashing sequences on control panel, with your service manual you can determine the exact fault. If you are machanically minded you can easily give your machine a service but would not attempt it if you don't know what you're doing. You can download copies of your product's service manual through 'manual's online' if you know someone else able to service your machine.
Probably a sticky dispenser door. Run for a few times with the dispenser open and put a tablet in the cultery basket
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
heatman101
There
are three common problems that cause the Soap Dispenser or Cup not to
open. I have a tip that will explain these problems in
detail....
Dishwasher Repair Problem Detergent
Cup does not Open
heatman101
The soap always lands on the dish closest to the dispenser. I have cleaned the inside of the dishwasher thouroughly, tried every kind of soap under the sun and even hired a company to service our water softener on a monthly basis. Frustrating! It's almost 2008- Rosie Jetson would not be happy if she new I was hand washing all of my dishes!
I am also having issues with the soap not dissolving. It sticks on dishes or it sprays and sticks all over the door. I don't even know what to try to do and fix it! I use gel soap, and it seems the problem is just getting worse. Please help!
Same problem here- Exactly! Soap is all down the inside of the door and the dish in
front of the compartment when the cycle ends.
I have run CLR, checked
the screen and I ensure that the water is very hot before running the dishwasher.
Same problem here - we find the soap at the bottom of the door undissolved and the dishes in the top rack aren't clean.
soap is not dissolving
same here.. noone has an answer?
My son was trying to be helpfull and put regular dishwashing soap in the diswasher. How do I clean it or take care of it?
Any suggestions
I ALSO have this problem
