GPS Logo
h
harry pilon Posted on Nov 12, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i get verbal direction on my tomtom gps
LP
Level 3:
  • Tomtom Master 514 Answers
  • Posted on Jul 11, 2019
LP
Tomtom Master
Level 3:
Answers
514
Questions
Helped
120810
Points
1285
Some TomTom GPS maps include verbal directions for use on certain TomTom models. If your GPS device has that capability, the map that you have on your device should be giving you verbal instructions.
If you don't hear any verbal instructions, check the volume and see if it needs to be turned up.
1 Related Answer
perdue40
  • 589 Answers
  • Posted on Nov 18, 2010
SOURCE: My Gps want give me
Tools....Settings.....Language.... under Voice select one that has an ending with ( TTS ) text to speech
3helpful
Re install new cards Canada/US
It may be possible that the new card you purchased (assuming it is for a new map) is for a map (version) that is compatible for your TomTom GPS. (It may be more helpful if you indicate the card/map and your TomTom GPS model) If you had purchased the card from TomTom ... contact TomTom for help.
Often, it is easier to buy a new map directly from the tomtom.com website . That way you'll get the "right" map for your TomTom model. After you pay for it, you download the map directly into your GPS (using the HOME application) and activate it. If you have any problem, you can contact TomTom right away and they'll help you to get it done right.
Mounting of gps can't mount on windsheild.
Tomtom GPS devices come with a variety of windshield suction mounts. All have in common that the windshield and the suction cup both must be clean; use a mild soap dispersed in some warm water to remove any dirt. Rinse properly. Sometimes it helps to keep the cup a little moist.
Make sure the cup is not warped due to previous exposure to heat, and check for any nicks in the rubber. Small damage may easily make the mount unusable and you'd need to get a replacement.
Models with a lever mechanic: open the lever (cup becomes flat), press the cup against the windshield and while keeping pressure, close the lever. It will lift the middle of the cup away from the windshield, causing a vacuum.
Models with a ring around the cup base: Turn the ring all the way counter-clockwise (cup becomes flat), press cup against windshield and while keeping pressure, turn the ring clockwise 90 degrees. This requires some force, but in my experience these mounts stick more reliable,
No verbal directions, just shows the route on screen
If you go to Preferences and click once, then click the arrow until you come too a pair of lips i think, click this only if it has Not got a cross through it, if it has then the unit has a problem
How do I know if I have tomtom Home installed on my GPS ?
tomtom home is located on your computer after you download it from tomtom...you can get it here just pick your operating system from the list.
after you download it and install it, just follow the directions and tomtom home will do the rest.
bill
The old route directions.
Hi
Download Tom Tom Home from here to update.
http://www.tomtom.com/services/service.php?id=16&tab=87
Check your home location is set correctly too,
For consistant directions.
Regards.
Screen continues to go out,touch it ,it reappears,every 20 second
Hello megbert, I own a TomTom also. I have listed the procedures from TomTom Home and hope this will work. First try a soft reset (Reset button is located at the bottom of the TomTom device next to where the DC plug plugs in). Make sure your batteries are fully charged up or the USB cord is plugged in.
If your device is not starting up properly, follow the steps below:
  1. Soft reset your device. *
  2. If your device still does not start up, then reinstall the TomTom application using HOME
If you have backed up your TomTom to your computer, then you can reinstall the TomTom application from your backed up data. *    In rare cases, your TomTom device may not start correctly or may stop responding. If this happens, try resetting your device. A reset does not delete any data.
New email address also cant remember my password so i can not log on what can i do
Phone your email service provider, and verify your identity verbally - they'll reset the password for you after confirming your address.
Sep 18, 2008 • Tomtom GPS
Top Tomtom GPS Experts
k24674
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
