SOURCE: fan making noise squeeking etc
ok not sure which fan or country your in but here in Australia if its the out door fan, should not cost more than $1200 if its the indoor roughly the same depending on access , may cost a bit more for labour but ... ok fan only cost indoor $600 outdoor $450 to $800 depending on weather the fan blade is seized or not, if its seized then a new blade can set you back To the $800 buck mark including the motor
SOURCE: goodman mini split unit condensating and leaking
Hi, your evap. drain is block, i know you are smart, we can do this, remove front cover of evap.(indoor unit) check for location of screws, look carefully you will see drain connection and tray, try to clean, use mild cleaning solvent, or practical way push something flexible into tubing, also clear your air filter, and you'll be in good shape, also check leveling of evap(indoor unit), with spirit level, should be horozontally leved. good luck.
SOURCE: i need wiring manual for goodman mini split.
outside unit L1 and L2 are load (input 240vac)
then you have control voltage, usually yellow and blue (24vac) this connects to some 18/2 thermostat wire which goes inside as white and red.
note: this unit may only need 24v control which is 2 wires from the inside unit and also 3 wires 2 hot 1 ground for line voltage.
STANDARD WIRING
on the inside unit you have green, white, blue and red control wires.
on your thermostat you have white, red, yellow and green
you run the wire from the outside unit to the inside unit. then run a 18/4 wire to the thermostat if wired and join the following wires.
inside unit thermostat outside unit
green------------------------green
white-------------------------white
red----------------------------red
blue-------------------------------------------------------blue
yellow--------------------yellow
