SOURCE: Mitsubish mr Slim air contioner heat & cooling control panel
HOW TO WORK THE HEATING AND COOLING CONTROL PANEL
- PRESS THE SWITCH ONCE IT OPERATES "COOL"
- PRESS THE SWITCH AGAIN IT OPERATES "HEAT"
- PRESS THE SWITCH ONCE AGAIN IT STOPS.
SOURCE: Climate control air conditioner stops working due to incorrect ambient air temperature
Same car, same problem. Press MODE, FRONT and REAR buttons together to reset tempreture. You probably need to replace the sensor GM part number 15047946 it is in the front grill email me for a picture. [email protected]
SOURCE: Sunbeam Model No. SCK 14200 DR no cooling...
Un plug a/c from wall and remove the screws from the electrical compartment of the unit and locate the thermostat, remove the 2 wires of the thermostat and use ohms meter to check the part for continuity, if you dont have continuity with t-stat turned down below room temp., replace thermostat.Good luck.
Testimonial: "When I hold the thermostat in my hand the digital temperature goes up. Is that proof that it is working?"
SOURCE: Air conditioner isn't cooling the room
hi there,
insufficient cooling have several reason,most common factor is low freon charging due to service factor,defective thermostat control,dirty evaporator and condenser fin,try to check the current rating using ammeter clamp tester if the rated current read in tester below the rated current on tag(compressor)
you need to charge freon,if the fin and evaporator is dirty need to ve clean,if the thermostat is not functioning replace thermostat.
also consider the main defective if the aircon is running chck the compressor if it is running by touching the tip of screw driver to the top body of compressor you can feeel vibration,if compressor is not running yo don't have cooling effect only blowing of air.on repairing this this should be done by a certified aircon technician,have a nice day fix my rate,thank you very much.
SOURCE: Air conditioner suddenly stops blowing cold and
If you are absolutely confident the AC compressor is not kicking out on low pressure then it is the blend door actuator.
The blend door determines how much air blows through the heater core or evaporator.
The actuator can be purchased at dealer and maybe at a local part store.
