SOURCE: the letters i type do not come out- they're other symbols
If you turn off and on and it types the proper letters at first then types gibberish look at the printwheel for bent spokes or other damage, then check to be sure tou have the proper correction tape (DRY).
Hope this helps
DickyO
SOURCE: keyboard letters are typing different letters
Hi Melaine,
It sounds like you're in a word-processing or text-editing application, and have selected a Symbol font. Change to another font (like Arial) and it should clear-up.
If I can be of further assistance, or if you have questions about any of my response(s), please let me know before rating me.
If this solves the issue, please rate it accordingly. My goal is to earn a "FixYa" rating from everyone I help.
Thanks for using Fixya.com,
Jon
SOURCE: My IBM Selectric II types the wrong letters.
Sounds like the cable might have slipped off the pulley, with the cover off, check all cables to the carriage assy. You need a tool like a spring hook to gently slide the cable back on to the pulley.
SOURCE: when you are typing it
Hi
Try system restore. Go to START>ACCESSORIES>SYSTEM TOOLS>SYSTEM RESTORE>CHOOSE PREVIOUS RESTORE DATES. Use other restore dates if needed.
Or try this
If your laptop keyboard types wrong characters, it is rather a software issue than an hardware one. This can happen if you accidentally press certain keys on your keyboard, which enable a certain kind of function.
Try the following steps in case your laptop keyboard displays wrong characters:
1.Go to the control panel option
Click ? 'Regional and Language Services' ? 'Languages' ? 'Details' ? 'Key Settings'
2.Select the option 'Switch Between Input Languages' and click on 'Change Key Sequence'
3.Ensure that all the check boxes are unchecked in this window and do the same for 'Switch to...(Keyboard Type)'
4.Click ?
'Ok' ? 'Ok' ? 'Apply' ? 'Ok'.
This should solve your problem
