SOURCE: i need a service manual
I just found that I do have a service manual for this washer. I thought I needed one myself. Send me request by text message to 011-973-3946 7127 and I will make you a copy at the same time as I make one for my technician.
SOURCE: hobart dishwasher lxic detergent pump will not run
Is the pump shaft turning during the wash cycle? If so I bet it is the same problem I had with my sanitizer pump on my 24" LXIc. remove the pump cover plate & replace the internal tube. Search this site for hobart LXIc sanitizer problem.
SOURCE: Dear hobart representative, are there any
Hello. thanks for using fixya. Here is a link to the hobart service office nearest you. http://www.hobartservice.com/Locations/
SOURCE: I have a LXiC Hobart dishmachine I do not want to
Do you realize that to sanitize with hot water alone requires 180 degree F water? I am a hobart technician and I've never seen any business or residence with hot water anywhere near that. Residential hot water is generally approx. 120, Commercial locations generally use approx. 140, but never near 180 (tap water that hot would be a severe safety problem). Hobart LXIH machines use a built in booster heater to boost the temperature of the incoming hot water up to the required 180 deg.
