Hi rednpat986.
this is all i could find,if this does not work go to the link at the bottom.
How to transfer photos from camera internal memory to SD card?
Follow these steps:
More items...
Transfer pictures from internal memory to a card - Kodak Support
camera How do transfer pictures from the internal storage to sd card...
I think you can through Android file transfer tool to transfer pictures from phone internal storage to a SD card, it is very simple.
At this situation, a wonderful data transfer tool is needed, then you can know easy to do. Here I recommend you MobiKin Assistant for Android tool to do, it is really safe and effective.
MobiKin Assistant for Android Windows Version MobiKin Assistant for Android Best Android File Manager to Backup SMS...
I think you can through Android file transfer program to do, it is effective for you to try, you can find the solytion of this way to transfer your photos from internal storage to a SD card, just use the follow program:
Prominent Samsung Messages Backup Software
SOURCE: internal memory photos download to sd card
1. Ensure memory card is inside camera.
1. Turn on camera.
2. Press Review button on back of camera
3. Then Press Menu Button on back of camera
4. Select "Image Storage" option (by depressing the joystick on RHS of back of camera).
5. Select "Internal Memory" option (by depressing the joystick on RHS).
6. Select "Continue"
7. Press Menu button.
8. Press "Review" button
9. Press "Review" button again.
10. Press "Menu" button.
11. Scroll down to "Copy" and select this option by depressing the joystick.
12. Scroll down to "All", then select by depressing the joystick.
13. Contents should now copy over from internal memory to SD card.
14. Don't forget to reselect Auto detection of SD card afterward. This is done by turning camera off then back on again. Press "Review". Press "Menu". Select "Image Storage". Select "Auto". Select "Continue".
SOURCE: pix transfer from internal to card
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card?
Answer :
Follow these steps:
SOURCE: Does anyone know how to transfer pictures from
menu,my pictures,options,manage my pictures,options, mark all,options, move,to card. Some phones have defects where the phone says memory card full when there is nothing on it., in that case youll have to take it in and get an exchange.
Testimonial: "Worked perfect!"
SOURCE: how to transfer pictures from internal memory to
Make sure a card is installed. In any still or video mode, press the Menu button. Press up/down to highlight Image Storage then press the OK button. Press up/down to highlight Internal Memory then press the OK button. (You'll need to set this to Auto later if you want pictures to go to a memory card instead of the internal memory.) Press the Review button, then the Menu button. Press up/down to select Copy>> then press the OK button. Press up/down to highlight what you want then press OK.
