Is it safe to use a microwave oven when the turntable motor seems to have burnt out-everything else works. It popped and sparked under turntable,seems to try to turn but the plastic top of motor is different shape now
SOURCE: kenmore microwave model 721.62644200
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: Russell hobbs microwave turntable wont turn
Is there an option via the Help or Custom Help to turn the turntable off and off?
This feature is common in over the range models.
Otherwise, it may be a bad motor.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand: http://www.youtube.com/watch?v=rPSWi_z7M58
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven, as you're looking up from the stove top.
Please write back with your model number if you need further help.
SOURCE: kenmore elite microwave oven displays "Locked" and will not respond
My Kenmore Elite microwave (don't have the model number in front of me) also mysteriously locked its own keypad (we were sitting in an adjacent room, heard a strange beep, and got up to find the LED reading "Locked."). I pressed and held down the Stop/Clear button for ~10 seconds and it returned to normal.
SOURCE: Owners manual for Kenmore Elite Microwave Model 66462
A full
Sears/Kenmore model number has 3 digits, a dot, then 8 more digits,
such as ###.########
You can just enter your full
model number at the Sears
parts site.
On the resulting page, look to the right for the blue "View manuals"
button. Click there.
That Sears-related site has many free manuals. While the manuals they
list there are all free, they will ask you to register.
Many times, the owner's manual will have the installation instructions
inside.
If yours is not listed there for free, you would have to order it
through the Sears
parts site.
We're
happy to help you with free advice and we'd appreciate your
SOURCE: rust under turntable of microwave can i paint it?
If the cavity metal of
the oven is chipped or charred, it will have to be sanded smooth and
clean and dried thoroughly.
Then you can apply some
high-temperature appliance paint, available from places like Wal-Mart,
Lowe's or Builder's Square.
We're
