Have the XGODY DDR4 Android 7.1 box which is 3 months old. It has been working fine connected to my Samsung TV until suddenly yesterday, it has stopped functioning. The blue LED light is lit up on the front display but no digits are showing ie. the time screen on the front is totally blank. The TV also no longer recognises the HDMI cable connection. I have tried using a different HDMI cable but it makes no difference, also have tried connecting the box to a different TV still nothing. Everything was working fine and it just suddenly went blank.
SOURCE: PS3 no longer communicating with TV
All: Try this -
Perform the following steps to reset the Video Output Settings.
NOTE: As of system software update version 1.60, the PLAYSTATION 3can
automatically detect an HDMI connection to a TV. If the PLAYSTATION 3
is turned on with an HDMI cable connected, the screen for switching
video output settings will be displayed automatically. (Does not
function unless the TV that is connected by the HDMI cable is turned
on.)
As of version 1.80 of the system update for the PLAYSTATION 3,
the PLAYSTATION 3 can upscale the video content of PlayStation® format
software, PlayStation®2 format software, and DVDs to HD resolution.
If Resetting the Video Output Setting Did NOT Detect Your HDTV Automatically (Certain TV's Only)
With certain televisions, the PLAYSTATION 3
may not automatically detect the HDMI source (TV) which it is plugged
into, even after resetting the Video Output Setting (as described
above).
If resetting the Video Output Setting did not work, you may need to follow these steps to manually locate the HDMI source:
1. Connect both the AV Cable and the HDMI cable from the PLAYSTATION 3 to the corresponding (AV and HDMI) ports on your TV.
2. Proceed with resetting the Video Output Setting on the PLAYSTATION 3 again. (Follow these steps, then continue to step 3 below.)
3. Turn the TV channel to the corresponding "Input" or "Video" channel for the AV Cable connection.
4. Manually change the Video Output Settings to HDMI. (Follow these steps, then continue to step 5 below.)
5. Now switch the "Input" or "Video" channel on the TV for the HDMI port the PLAYSTATION 3 is currently plugged into.
6. Accept the display settings for HDMI before the timer runs out (30 seconds). Highlight "Yes" and press the X button.
7. You can now disconnect AV Cable from the PLAYSTATION 3 and the TV, as it is no longer needed.
the PLAYSTATION 3 may not automatically detect the HDMI source (TV)
which it is plugged into, even after resetting the Video Output Setting
(as described above).
SOURCE: Display not working
how down the power button until it beeps twice. that will restart your settings for the display. once it beeps twice then turn the system on and change the default settings back to your hdmi settings. what happened was when you transferred the ps3 to composite the settings changed to accomodate that but when you switch back to hdmi it doesnt change back. the only solution is to hold down the power button untill it beeps twice. normaly 3 seconds.
SOURCE: TV wont detect HDMI Devices except a pc.
Something is wrong whith the HDMI jack it's self, or the electronic switching is not sensing a signal is present. In either case the board that has the HDMI jack you are using needs to be replaced. Most all these boards are double printed, Multi-layered or both which prevents replacing the jack it's self. I do have a question though, do you only have on HDMI jack on the unit or do you have another one available.
SOURCE: on a Daytek 46 in LCD TV, no AV Digital Cable Signal, but HDMI OK
Had the same problem.
Fixed by unplugging everything from the power source, leaving for 2 minutes then plugging back in.
Works fine now.
