I have a Lexmark X6170 ALL-IN-ONE Printer. While trying to print. I receive a message telling me to reinstall the printer cartridges. After doing so. I power the printer back up and I get Cartridge Error "error 50C" message on the printer display. Does anyone have some information on how I can correct the error message? Thanks! John
The 0502 error code indicates either a faulty cartridge is detected or the encoder strip (transparent strip) is dislodged from its position. Refer to this article in the Lexmark website on Error 0502 on the Lexmark X6150/X6170 Printer LCD Displayto determine and resolve the problem. Thanks.
The error is telling you that the color or black cartridge is missing. It's not recognizing one of your cartridges, most probably the new black cartridge. Here's a link to the Lexmark website to guide you on what to do with that problem. http://bit.ly/bkCWPF
Hi. The error tells you that your print cartridge has shorted. Here's a link to the Lexmark website to give some instructions on how to remedy the problem. Just click on this link: http://bit.ly/aSWvpk . Good luck!
Error messages; Error: "Cartridge Error 50C"; Cartridge error; Black cartridge missing; Color cartridge missing
Solution
Cartridge Error 50C Your print cartridge has shorted.
Power off your All-in-One and unplug it.
Plug in your All-in-One again and turn it on.
Uninstall and then reinstall your cartridges.
If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing The black cartridge is not installed. (Install cartridge PN 82) Error: Color Cartridge Missing The color cartridge is not installed (Install cartridge PN 83) Cartridge Error Complete the following instructions:
Power off your All-in-One.
Use both hands to lift up the scanner unit until the scanner support holds it open.
Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
Remove the color print cartridge.
Lower the scanner unit until it is completely closed.
If the error message reappears, replace the black print cartridge with a new print cartridge. If it does not repeat steps 1-3 and then go to step 7.
Reinstall the color cartridge and remove the black print cartridge.
If the error message occurs again, replace the color cartridge.
If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
If you receive the error message again, replace both cartridges.
Is that an error code "Cartridge Error 50C" ? If so, see below....
Cartridge Error 50C: Your print cartridge has shorted. 1. Power off your All-in-One and unplug it. 2. Plug in your All-in-One again and turn it on. 3. Uninstall and then reinstall your cartridges. 4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing - The black cartridge is not installed. (Install cartridge PN 82) Error: Color Cartridge Missing - The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error: Complete the following instructions: 1. Power off your All-in-One. 2. Use both hands to lift up the scanner unit until the scanner support holds it open. 3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy. 4. Remove the color print cartridge. 5. Lower the scanner unit until it is completely closed. 6. If the error message reappears, replace the black print cartridge with a new print cartridge. If it does not repeat steps 1-3 and then go to step 7. 7. Reinstall the color cartridge and remove the black print cartridge. 8. Lower the scanner unit until it is completely closed. 9. If the error message occurs again, replace the color cartridge. 10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges. 11. Lower the scanner unit until it is completely closed. 12. If you receive the error message again, replace both cartridges.
Hi Marty, naughty printer. It is not reading your new cartridge. Clean your printer with own program and if this faild do it youself with cotton tips and proper cleaning solution. Try printing now. Dn't forget to reset ink and cartridge settings for new ones. cheers lilac gerry xxx
