My stereo was stolen. It was a professional job, (I would say) they cut wires at the amplifier, stereo and sub woofer. I purchases a new stereo, and got the door speakers replaced (yeah, they went missing too!). Didn't think about the amp or the subwoofer, however, when installation of the stereo began, I noticed before I went to the audiologist for car stereos, the amp and subwoofer where gone. So, I got them for my vehicle by the vin#. The wires are all different colors! Need diagram to see where wires go....JP
Try this link. Wiring diagram for 2006 nissan pathfinder LE sub woofer spreaker Google...
or this link... Wiring diagram for 2006 nissan pathfinder amplifier Google Search ..
not sure if the links will help you out but have a look.
SOURCE: Identification of original wiring to car radio/stereo
no wiring diagram needed go cut a plug from a junk yard and wire it into the cut wires then buy the adapter kit for you car and wire that to the car plug and the radio plug.
SOURCE: 2005 Neon SXT Stereo Wiring Diagram
2005 Dodge Neon Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink/Light Blue
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Orange
Car Stereo Dimmer Wire: Black/Yellow
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
SOURCE: PIONEER 300 WATT CAR STEREO AMP WIREING HOW TOO
depending on how many channels the amp is, you may not be able to hook everything up to it.
usually you have a separate amp for subs. 4 channel amp for the speakers in the car, and a mono amp for the subs.
To hook them all up to the same amp you would need an amp with 5 channels. It wouldn't work out right.
If you have a mono amp its only for subs.
If you have a 2 channel you can either hook it up to the rear speakers or bridge them to mono to run the subs.
you need a channel per speaker basically.
SOURCE: installing aftermarket stereo. cannot locate a
BEST BET IS TO GO TO A STORE THAT SELLS &INSTALLS.... I,VE HAD THEM MAKE A COPY OF A SCHMATIC BEFORE... ,CHARLIE
SOURCE: need factory stereo and speaker wiring diagram for '08 Ford Fusion
2008 Ford Fusion Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Red
Car Radio Accessory Switched 12v+ Wire: Green
Car Radio Ground Wire: Black/Blue
Car Stereo Antenna Trigger Wire: Purple/Black
Left Front Speaker Positive Wire (+): White
Left Front Speaker Negative Wire (-): White/Brown
Right Front Speaker Positive Wire (+): White/Purple
Right Front Speaker Negative Wire (-): White/Orange
Left Rear Speaker Positive Wire (+): Brown/Green
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Brown/White
Right Rear Speaker Negative Wire (-): Brown/Blue
