SOURCE: I can't connect to the router
Well since ur second computer goes online with wireless connection, so it seems the problem with your first computer.The only thing that you have to do is to update your wireless card drivers. Detailed answer: 1. Restart your computer in safe mode with networking mode. 2. Uninstall the wireless card. 3. Restart the computer and install the card again. This will definitely resolve your problem. Goodluck. ( Got the solution from ***)
SOURCE: Wireless network on sony vaio
Sir,
check the links below and go through the sites......u have a solution
Link 1
Link 2
Thanks
Good Luck
Appreciate to rate as "Fixya"
SOURCE: Linksys Wireless-G USB Wireless Network Monitor\wlan.ini can't
Start -> Control Panel -> Classic View -> Add/Remove Programs
Find the entry for the Linksys device.
Click "remove".
When it finishes, shutdown/reboot.
SOURCE: IBM Thinkpad will not turn on wireless connection
1st go to MY COMPUTER, RH CLICK-PROPERTIES,HARDWARE TAB, DEVICE MANAGER,NETWORK DEVICES. CLICK ON THE + TO OPEN THE INSTALLED
NETWORK CARDS. YOU SHOULD MOST LIKELY HAVE 2 LISTINGS 1- YOUR ETHERNET PORT
2-YOUR WIFI CARD. THERE SHOULD NOT BE AN EXCLAMATION POINT OR A QUESTION MARK, EITHER INDICATING A PROBLEM. IF YOU DO HAVE EITHER LOOK AT THE DRIVERS 1ST AND THE ACTUAL HARDWARE 2ND. IF BY CHANCE YOU DONT SEE YOUR WIFI CARD
THEN TRY REMOVING IT AND REINSTALLING IT. TURN ON YOU COMPUTER AND SEE IF
XP RECONIZES IT "NEW HARDWARE FOUND". YOU HAVE TO SUPPLY A DRIVER FOR IT AS
WELL. GOOD LUCK
SOURCE: I Have NoteBook Sony VAIO
As Sony does not support installation of Windows 7 in your computer model, you can install the Vista drives from the below, It will work.
Audio driver:
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNFS8900&upd_id=2729&os_id=27
Wireless Driver:
http://s02.download.sony.com/US/pc/INDWLL-00164641-US.EXE
Video Driver:
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNFS8900&upd_id=2500&os_id=27
Mass Storage Driver:
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNFS8900&upd_id=2619&os_id=27
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNFS8900&upd_id=2695&os_id=27
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNFS8900&upd_id=2631&os_id=27
Thanks
Once you have all the wireless settings of the router, you are ready to connect the play station or the x-box to the wireless network.
Play Station
Now go to the settings page of the PLAY STATION
NETWORK SETTINGS ==>
INTERNET CONNECTION SETTINGS ==>
WIRELESS SETTINGS ==>
If you get confirmation screen displayed stating that you will be disconnected from the Internet. click YES ==>
select EASY ==>
select WIRELESS ==>
SCAN ==>
you will see your SSID ( wireless network name)==>
select the security settings ( router wireless settings)==>
enter the KEY ==>
select the IP address settings EASY ==>
save your settings ==>
Test the connection .
Play Station
select EASY ==>
select WIRELESS ==>
SCAN ==>
you will
select the
enter the KEY ==>
Test the
connection .
