SOURCE: STIHL FC90
the fastest way is to replace the line it connects to pull the old line out take the new hose and trim it down to 1/3 about a 1/2 long feed a stiff wire threw the hose opening and out the gas cap opening slide the line over the hose and slowly pull the wire back til the hose sticks out then pull the hose threw connect the filter to the hose then pull into place trim the hose to size
SOURCE: leaking fuel tank stihl fs76
no seals just the tube seals itself to the hole in the tank for it
sounds like a split in the fuel line to the fuel filter
SOURCE: have a stihl 024 goes ok on a full tank but when its half full it
the filter in the tank isnt getting to the bottom of the tank hose inside is to short
SOURCE: Where can I get a STIHL-CHAINSAW MS361-REPAIR-SERVICE-MANUAL
Here's another service manual for your Stihl,they don't make this model no more. Stihl MS361 Service Manual Cylinder Engine Clutch
Testimonial: "Thank you Thomas! Terry"
