I'm wondering around the internet to find some couple of solution for this error. i tried clearing cache and relog doesn't seem to be the solution.. finally i found something that makes sense. https://www.errorsolutions.tech/error/netflix-error-code-nw-2-5/... by doing Solution 2. Check Network Hardware..
Solution 5. Reinstall Netflix
Netflix Error NW-2-5. If you experience the error code NW-2-5, it typically points to a network connectivity issue that is preventing your device from reaching the Netflixservice. Follow the troubleshooting steps for your device below to resolve the issue.
How to fix Netflix Error NW 2 5
SOURCE: "No signal" on hdtv while trying to watch netflix via xbox
First you need to eliminate the possibility that
the box is loosing video feed from the G.P.U.
hook the unit up in with normal yellow
white and red a/v connection for standard TV
out . if it happens shut the unit off and on again
and if you have sound and no video it's the G.P.U
becoming disconnect , the fix for this is to have
the chip re-flowed back to the P.C.board .the other
cause is a failing HDMI cable but im guessing you
already replaced that.
If you have any questions feel free to ask
Rob
Testimonial: "Very helpful"
SOURCE: Content error when trying to
update your tv manually. you can download the software update from esupport.sony.com
SOURCE: Hi. I am trying to
Goto settings date and time and tell ps3 you are on daylight savings time. Then delete Netflix and reinstall.
SOURCE: HOW DOES NETFLIX WORK AND WHAT EQUIPTMENT DO I NEED TO WATCH IT ON TV
I am assuming you are residing in the US. Providing that and that you have an internet connection, you're pretty much set up. Make sure your browser is up to date and will work with Microsoft Silverlight (most modern web browsers do). Sign up for the service or start your free trial. What else do you need to go with netflix? Popcorn maybe?
SOURCE: We bought this tv because
Its not your TV its Netflix. Go to Netflix Watch TV Shows Online Watch Movies Online and find the support link.
