SOURCE: Guitar strings on a mandolin.
By now you may have solved this problem, but maybe this information is still helpful:
What you are essentially recreating is a tenor guitar. Many companies make tenor guitar strings. I would suggest D'Addario J66 80/20 Bronze Tenor Guitar Strings (10-32). I've done this a few times and it is quite fun and makes for an interesting travel guitar.
Have a blast!
SOURCE: string buzzing
Dont give up on the neck. One tec you saw may not know what another that has had many years in the repair of gtrs knows !. But for the time being you can fix this your self. Find a alan wrench that came with your Gtr.thats your ntail pice. This is the bridge that each string cross,s over. Now slowly rase up the height of the string untill its high enough to stop the buzzing. Just half turns at a time. . All so if you keep the humitdy up near your gtr. it may correct its self, no **** just like magic. keep on playing DFD
SOURCE: how to get a fat and clear sound from schecter
Ninety percent of what you want depends on the amp and speaker you are using.
You likely will want a 15 inch speaker in a bass cabinet to start with and a decent midrange driver as well.
No amount of EQ will fix an audio system that just can't put out the bass tones.
SOURCE: I have Ibanez gsr200 bass guitar , yesterday and
No question what to do... take it in under warranty since it is new !!!
You may find that there is a problem with your amp... the seller should be able to test the guitar and demonstrate normal sound for you.
Many users have TOO small of an amp and the distortions make it appear that the guitar is bad... I suspect you will want at least a 12 inch speaker and preferably a 15 inch for your bass.
When low frequency signals drive a speaker too hard it drives the voicecoil out of the linear range and the sound will be irregular..
Testimonial: "Thank you:)"
SOURCE: i need wiring diagram for ibanez gsr200 bass
Here is a diagram:http://forum.ibanez.com/default.aspx?g=posts&t=78892
