Voice dialing to phone app doesnt work properly connect to pc and pbluetooth ok, but when you push mtb to voice command the phone b250 goes to apple screen but tones will be the iphone connects to ipone ok but b250tx voice comes on before the connection. thanks all for the help
I searched for ages before I found the solution to this. Just plug the 2nd handset into the base station as though you were charging it. You'll see the red light in front flicker for a few seconds. Wait five seconds after it goes solid red again and remove it. Press the "find phone" button on the front of the base station. If both phones beep, you're all set. If not, rinse and repeat.
Full owner's manual is here: http://www.uniden.com/pdf/DXI5586-2om.pdf
SOURCE: lack of dial tone with modem on Toshiba Satellite Pro L20
just go to the modem properties and you will see a option there called wait for dail tone if u see tick mark there please remove the tick mark your problem might get solved. if this doenst work then check up ur cable and the modem
SOURCE: I dont get the dial tone when connected to the
I have been using Avaya for the past 6 months. I have faced similar problems. May be you can try connecting the phone in place of another IP phone and check if the problem persists. This can isolate the problem whether it is with the phone or the network.
For your reference I shall provide with the online manual.
http://support.avaya.com/elmodocs2/2410/16_300133_1a.pdf
And if you arn't able to find the solution in there, the probably you need to contact tech support.
Good luck !!!
SOURCE: after power cut the phone will not connect,it just
I think if you switch off by holding down the 'exit' key for about 10 sec, then switch on again (same key) it might recover. Mine did, but seems to need the process repeating from time to time. When switched on again it still has to search for about 5 minutes.
