I've had several microwave ovens over the years, both painted and stainless, and this is the first time I've encountered paint peeling.I've had 20 years experience in Radar systems (which a microwave is although simplified) and 20 years experience in X-ray so I am aware of the electronic and physical properties of radiation. When I started the cavity restoration I found the paint peeled off easily in two areas in the roller path (180 and 90 degrees) there was no rust so I am assuming the problem was improper prep of the cavity during manufacture. Additionally, the paint issue caused uneven wear of the rollers on the ring so the roller ring required replacement, It has been 24 hours since the bottom of the cavity was wet sanded, cleaned with acetone and painted with QB microwave oven paint and all looks good so far. The paint and roller ring were purchased from Amazon, the sandpaper and acetone from Walmart for a total cost of $50.00 plus one hour labor. The original price of the microwave in 2017 was $172.00, today that oven will cost $249.00 to replace, so if the repair holds I will have saved about $200.00 and if not lesson learned. To anonymous who said the magnetron was defective causing the paint issue , I have to disagree. A magnetron is a tuned cavity diode and will fail in three ways assuming no metal objects were placed in the cavity and the oven operated: open filament (no cooking), shorted tube (blown fuse or failed electronics) or reduced power output due to age/use. I don't have any experience in replacing a magnetron in a microwave oven because it has not been cost effective to do so unless the oven is a high end oven.
Dont ever in future buy a microwave with a painted interior as it will always peel.......better to buy a stainless steel one.i don't know if there is a special paint you can buy but if you look on the internet you will find one.
SOURCE: Paint off inside top of microwave exposing metal. Safe to use?
It would be dangerous to do so. Any exposed metal inside a microwave is source for sparks and is extremely hazardous. I would recommend getting the paint job done up, or even better, buy a newer model.
SOURCE: Okay, I've never done this
the magnetron is defective you need to send this to a shop im afraid
SOURCE: rust under turntable of microwave can i paint it?
If the cavity metal of
the oven is chipped or charred, it will have to be sanded smooth and
clean and dried thoroughly.
Then you can apply some
high-temperature appliance paint, available from places like Wal-Mart,
Lowe's or Builder's Square.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
SOURCE: My Panasonic Inverter Genius Sensor 1250W Lights
microwave is in lock mode. How do you unlock to use?
SOURCE: microwave runs for 3 seconds and stops
See if this describes
what's happening:
If so, see http://207.234.249.73/mwd/safety.txt , http://207.234.249.73/mwd/disassembly.txt and http://207.234.249.73/mwd/doorsw.txt
Otherwise, if
the digital programmer circuit / controller does not get a feedback
signal from the inverter for a period of 3 seconds, the controller will
stop the cook cycle.
That may be a loose connection in the wiring between the
inverter, magnetron, and/or control board, or maybe one of
those
components has failed.
Due to the lethal
voltages used and produced in inverters, I do not recommend that an
inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
We're
happy to help you with free advice and we'd appreciate your thoughtful
