You have to be sure bucket is replaced exactly where it should go or the bucket will hold the switch in, thinking it is full. If you have a floor drain close by,remove the bucket and set the dehumidifier over or next to drain so water will go down it,then you don't worry about bucket getting full.If it doesn't run with bucket off, maybe defective switch. unhook wires to the bucket switch and hook or tape together,if dehumidifier runs then switch is bad. UNPLUG FROM OUTLET BEFORE DOING THIS. IF YOU DON'T UNDERSTAND ELECTRICITY GET QUALIFIED HELP!!
First, check the source of the power to the unit, Has a circuit breaker in your home's circuit breaker panel been tripped? If so, unplug the unit, before resetting the circuit breaker. If that's not the case, check the outlet it's plugged into. It may be damaged or have a loose wiring connection. Be sure to turn the circuit breaker for that receptacle OFF, before removing the cover plate.
If all of the above checks out OK, check the water collection bucket, as it may need to be emptied and/or the bucket was not reinstalled properly or the float valve in the top of the bucket is stuck in the UP position, If so, jiggle the arm of the float valve to get to return to the DOWN position.
When reinstalling the bucket, be sure that it fits "squarely" into it's holder and makes firm contact with the bucket safety removal switch.
I hope this helps you to troubleshoot & solve the problem. Thanks for choosing FixYa.
Hi, There are many reasons why a dehumidifier willnot work or collect water. Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
If the room air is less than the set air then there is no water in the
bucket because there is almost no humidity in the air. If it is winter,
there is likely not enough humidity in the air to have water collect in
the bucket.
A dehumidifier will only pick up humidity out of warm air. If you are
running a dehumidifier in your basement in the winter, the room may be
damp, but too cold for the dehumidifier to pull out the humidity.
Try running the unit in the bathroom after having a hot shower without
the bathroom fan on. If working correctly the unit should draw water.
In addition, check to see if the air filter is dirty and/or blocked. Also, the room temperature might be too low, (below 15.5 C/ 60F) and finally, check to make sure that there is no obstruction to the unit, that might be causing poor airflow circulation.
I hope this helps you to troubleshoot and solve the problem.
Nicole, some of the packing material may have gotten into the drain tubing or hole and clogged it. Remove the water reservoir and look for a vinyl tube or drain hole in the cavity that the "bucket" came out of. If you can see anything blocking it, carefully remove it. I don't think at this point anything would have gotten any further down the drain tubing. Since this a brand new unit, consult your Owners Manual for directions on how to Troubleshoot this problem. If that fails, it's under warranty. Contact the manufacturer as directed in the Owners Manual.
Hi, There are many reasons for a dehumidifier tto not work or collect water. Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier.
