m
mary heafner Posted on Oct 23, 2017
I have to get my gpx bc232r to operate on batteries. i have all i know to do. please help.
I dont have a remote for a GPX tv/dvd combo model number: TD3220BRS. Does anybody have or know where I can get a universal or gpx remote that is compatible with my device please n thank u???????????
Hey Buddy GREAT NEWS !! I found this page on the internet, & here is the link below at the bottom, below some of the text from the page that I also copied and pasted for you:
Get GPX DVD remote codes! If you have a GPX DVD player and want to control it with a universal remote control, we have the codes needed. A GPX DVD player can be controlled with any universal remote if you have the correct programming guide and the correct remote codes. If the codes below do not work with your GPX DVD player, please leave a comment below with the model number of your remote control and DVD player and we will find you the correct remote code.
http://codesforuniversalremotes.com/GPX-DVD-Player-Remote- Control-Codes-Codes-For-Universal-Remotes
AND AS A SPECIAL BONUS JUST FOR YOU !!! YES !! All the remote codes you are likely to need. These guys will even help you out if you still nee help
Program your universal remote control to a GPX DVD player. Use the following remote codes.
GPX DVD Player 4 Digit Remote Control Codes:
0936
0944
2114
2390
And if by chance this info just doesn't work, please just go to the " CODES FOR UNIVERSAL REMOTES " WEBSITE, as these guys seem to be real " FIRETRUCKIN' GOOD !! "
GOOD LUCK TO YOU !!
Geoff
1helpful
Does it exist?
Please confirm model number
number of batteries in the battery bay 3,4 or 6
2helpful
2answers
Need gpx tv universal tv code for RCA universal remote
As you have likely discovered, most universal remotes do not list GPX as a device. GPX is a low cost version of Sony devices, in most cases the Sony device codes will operate GPX devices.
I have a RCA 3 device remote that I use the Sony TV code on and it operates the GPX TV just fine.
Hope this helps out! Most people do not know GPX is the cheap versions of Sony devices.
Can't play the cd
After putting in the CD, move the switch on the back to the CD/Line In position. (The other switch positions are Off, AM, FM.) The switch is next to the Line In (3.5 mm) jack. Then press Play/Pause on the front of the boombox. This is the single button on the left side (The adjacent pair of buttons are the search (reverse/forward tracks). On the other side of the LCD display are the Stop, Repeat and Program buttons.
GPX has the manual for the GPX BC232 on the product page: http://www.gpx.com/store/p/822-BC232R.aspx . Click on the tab for Downloads to get the manual link. The direct link is http://www.gpx.com/owners_manuals/BC232-578-01-IB.pdf . You will need Adobe Reader or a similar program to access the manual.
I hope this helps.
Deleteing music from GPX mp3 player
open the gpx file and manuallt delete take the battery out before you connect to the computer it might cause an error and wont sync up with a media player
2helpful
2answers
How do i charge my gpx?
plug it into the computer through the mini usb dugh
Feb 14, 2009 • GPX MW3337G
3answers
2answers
GPX MW3836
take your battery out plug your usb into your computer then it should say USB when it says this go to my computer it should say GPX device
Top GPX Audio Players & Recorders Experts
SmartAviator
SmartAviator
 Grubhead
Grubhead
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
