Refrigerators Logo
R
RAMON MENA Posted on Oct 23, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
YOU HAVE THIS PART # DA41-00100A PARA REFRIGERATOR SAMZUNG
David Ellis Rhea
Level 3:
  • Refrigerators Master 3,462 Answers
  • Posted on Oct 23, 2017
David Ellis Rhea
Level 3:
Answers
3462
Questions
Helped
786195
Points
10903
We have no parts.
We are a service that offers free opinions on how to fix stuff around your home.
Try Amazon, or "SearsPartsDirect:" or e-bay.
How to open line my samzung gt c3053
There can be many ways to Unlock your phone. As far as i know unlocking by codes is the simple and safe way. I will suggest the website Unlock-Zone.com which is doing good service and they were recommended highly in the cell phone forums.
I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.
ESTOY EN VENEZUELA EL DISPENSADOR DE AGUA Y HIELO NO FUNCIONA (MODELO TFX27PF REFRIGERATOR-FREZER QUE PIEZA NECESITO PARA SUSTITUR (SERIAL)
You would want to first check your water valve. It is a dual water valve. I suspect your solenoid for the water in the door has failed. Let me know Amigo.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mi refrigerador lg puerta francesa, se congelan las correderas que puedo hacer para solucionar este problema, existe algun producto para colocarle a los rieles del refrigerador y evitar que se congelen y...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Cambie el filtro por uno nuevo y la luz sigue prendida en rojo como cambio a color verde
Una vez que filtran la luz se vuelve roja, sigue siendo rojo hasta que se resetea. Para restablecer el indicador del filtro, presione ambos LOCK y DISPENSADOR DE AGUA
botones simultáneamente y mantener durante 4 segundos. Hacer luz verde que parpadea tres veces cuando el indicador
se restablece.
2helpful
Tengo un frigorifico Magic chef modelo GC20B 7C3EV. el compresor esta funcionado normal, pero no llega frio al refrigerador y el congelador se esta descongelado, parece que no hay circulación...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
SUENA UN PITO
El pito es debido a un mal funcionamiento lo que tenes que hacer es llamar a un tecnico para que te cambie el Main Control Board, y con eso se iran los sonidos.
I CAN NOT PUT THE FILTER NO. 4396508
READ INSTRUCTIONS ON BOX YOU TWIST OUT OLD ONE IF THIS IS ON BOTTOM OF REF
2helpful
HAVE AN LG FRIDGE MODEL LRFC22750. THE LIGHT
EFFECTIVE FROM(SERIAL NO.) from 704MR***** to 801MR***** Subject Lamp Cover Melting Improvement (LG 3D Basic) / 2nd No. Loc No. Before Change After Change Note K-Code Remark Part No DESC./SPEC. Part No DESC./SPEC. 1 501A 6871JK1011A PCB Assembly,Main /
6871JK1011D PCB Assembly,Main /
WINNER1 DISPENSER ENERGY STAR '08 C 3 Change Relay SPEC. 2 503F 3111JJ1001X Case Assembly,Display /
WINNER1 BASIC BRAND ABQ33905315 Case Assembly,Display /
SOLO PARA SERVICIO, NO PARA PRODUCCION C 3 Thermoprotector addition. 3 503F ABQ33905304 Case Assembly,Display /
SOLO PARA SERVICIO, NO PARA PRODUCCION C 3 Thermoprotector addition. 4 409B 6912JK2002C Lamp,Incandescent /
60W 120VAC 0.40A 480LM - WHITE 6912JK2002E Lamp,Incandescent /
C 3 60W to 40W
No sound
If your TV is a Samzung, and has the Anynet+ function, you need to set the TV up with the Theater system. If there is an Anynet button on your TV remote, push that, and then select the function that sets up the sound system to the TV. If you don't see that button on your TV remote, then look for the option in the TV menu section. Once set up, you can use the menu under that Anynet button to turn off the sound system and return to normal TV audio... and while using the sound system audio, you can control the sound system volume, or mute it, with the TV remote.
2answers
Jenn-Air Side by side. The freezer compartment ices up and the refrig does not get cold.
the switch in the back of the ref. needs to be replaced it just happened to ours
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
