Question about Braun Office Equipment & Supplies
Where is fuse in braun paxiscope 650?
Dropped projector and bulb looks ok, fan comes on but light wont come on....?
6ya staff
SOURCE:
kleankutken
  • 6 Answers
SOURCE: I can't get the light to come on.
Sounds like your black screen shutter is not opening allowing light to pass through. Try it with the carousel and slides installed. Run a few passes.
Posted on Dec 08, 2007
ABRsvcs
  • 4234 Answers
SOURCE: 250V T6.3AH Slow Blo Fuse
Depending upon the way in which the lamp finally smoked, it is not unusual for the feeder fuse to blow. Replace the fuse and try the projector. As long as you haev a new lamp, it should work OK.
Dan
Posted on Sep 11, 2008
Anonymous
SOURCE: XR-10x bulb timer has timed out. How do I reset the projector?
you need to reset the lamp timer see http://www.ercservice.com/PDF/Lamp-Sharp-XR10-XR20.pdf
Posted on Apr 16, 2009
super_guy
  • 1986 Answers
SOURCE: brake lights don't come on. checked fuse box,
look up above your brake pedal and you will see the switch.. It will either between the firewall and the pedal arm (switch moves in when you brake).. Or it will be between the pedal arm and the dash (switch moves out when you brake)
Posted on Oct 08, 2009
Kiri Amarakoon
  • 290 Answers
SOURCE: no low beams bulbs are ok fuses look good
There may be a relay that operates the low beam lights, check the owners manual to see if there is a relay, you should be able to hear it go "click" if there is one.
Posted on Dec 26, 2009
Projector powers on but bulb doesn't light up. Changed bulb, still doesn't work. Tried original bulb in other projector, works fine.
If you feel that it is working abnormally you can send it to service. In the USA Braun service is: HP Marketing Corp. PO Box 715 16 Chapin Rd. Unit 908 Pine Brook, NJ 07058 800-735-4373
Otherwise contact the service center in your country.
Mar 05, 2011 | Braun Novamat E150 Slide Projector
Turn on benq pb6200 with new bulb all I get is humming and no led
same problem here. checked fuse, mainboard seems ok. nothing looked blown.
Jul 15, 2010 | BenQ PB6200 Multimedia Projector
Have a KDF 60Wf 655 will not turn on. Green light comes on then red light with 7 blinks any suggestions? Took bulb out but the bulb light never lit and the bulb doesn't look blown.
Wether it looks blown or not replace it and dont put oil from your fingers on the bulb. Also clean the cooling fans for the bulb and projector (which may mean taking the back off and taking apart projector). Dirt in the projector fans can cause a fault not allowing for the unit to turn on. All the cooling work ins conjunction with a good bulb.
Apr 24, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
BenQ DX 650 Won't power up making clicking noise
Those units are designed to be fan cooled after the bulb shuts off. When the cord was pulled, the unit lost power and without the fan, sat there and cooked. Could be a thermal fuse, could be the bulb.
Mar 10, 2017 | BenQ DX 650 Multimedia Projector
Optoma hd65 projector new bulb wont turn on...cant reset timer!
I think it's a lamp driver issue from what I've seen others have gone through. I also read that if you go through the sequence of unplugging, plug back in, wait 20 seconds and try to turn on, multiple times, it will finally kick on and work. I just got mine to turn back on by doing this and waiting through the fan cycling without the light turning on. After the 4th sequence the light flickered. After the 7th sequence it finally turned on and is working. Now I can watch the Super Bowl and will look into replacing soon.
Jan 31, 2010 | Optoma HD65 DLP Projector
Epson ELP 3000 clicking noise and all lights flashing
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Mar 26, 2009 | Epson (1023661) Projector Lamp for...
Dan
Sep 11, 2008 | NEC VT670 Multimedia Projector
Projector problem
I generally fix this by re-seating the bulb housing. Take it out and put it back in. Look for cracking at the base of the bulb on the mirrored surface. It could be a barely functioning bulb that isn't busted, but can't initialize. I would take it to a shop that has the same bub type in a housing and make a quick switch.
Jun 20, 2008 | InFocus ScreenPlay 4805 Multimedia...
The projector lamp comes on (amber color) no image
I was told by an expert that the fan should come on as soon as heat starts to come on. You should never turn a projector off with out the fan running for a while to cool the bulb down. Each projector is different but the fan has to operate on then all. There is so much heat in the bulbs that air has to keep them cool when they are operating as well have to cool gradually when they are shut down.
Mar 02, 2017 | Dell 2300MP Multimedia Projector
73 people viewed this question
Top Braun Office Equipment & Supplies Experts
Ekse
jasbo
jasbo
Are you a Braun Office Equipment and Supply Expert? Answer questions, earn points and help others
