Computers & Internet Logo
Geamari Hunter Posted on Oct 22, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When i turn on my blackberry pearl or plug it to my computer it wont turn on. so what should i do?
Don A
Level 3:
  • Computers & ... Master 4,384 Answers
  • Posted on Oct 22, 2017
Don A
Level 3:
Answers
4384
Questions
5
Helped
1319665
Points
25577
You have not indicated if the blackberry will run when absent a battery it is plugged into a charger. If it does, that suggests a battery problem and you simply need to replace the battery. If a red light blinks on the blackberry when you try the above, try a hard reset. But before that, try the below.
Push and hold the call button and alternate with the end call button until the hourglass shows. Allow some time to boot up.
Here is the hard reset procedure:
http://www.hard-reset.com/blackberry-9100-hard-reset.html
You may contact Blackberry support if this does not work.
5 Related Answers
Anonymous
  • 87 Answers
  • Posted on Nov 19, 2009
SOURCE: how i connect my blackberry to my computer
Hi, install desktop manager latest version, then you can connect blackberry pearl using usb cable. If you dont have desktop manager software cd, you can downalod it from blackberry.com. I hope this information will be helpfull.
Testimonial: "thanks"
Anonymous
  • 541 Answers
  • Posted on Nov 21, 2009
SOURCE: i cant turn on my blackberry pearl 8110. Red light just flashes
A hard reset involves physically removing the battery from the smartphone and then reinserting it. To perform a hard reset, complete the following steps:
1) Remove the battery cover from the back of the BlackBerry smartphone.
2) Remove the battery, and then reinsert it after a few seconds.
3) Replace the battery cover.
Still if it is not working kindly remove the Battery of the Handheld and try in some other Handheld.
If the Battery is working fine in the other Handheld then there might be some problem with your Handheld, you need to walk into the service center.
If the Battery is not working in the other Handheld then there might be aproblem in the USB cable for these you need to walk into the service center
Anonymous
  • Posted on Mar 06, 2010
SOURCE: hi my blackberry pearl has a blinking red light
It means your battery is COMPLETLY DEAD
Anonymous
  • 11 Answers
  • Posted on Dec 28, 2010
SOURCE: My phone died overnight, n
ITS YOUR BATTERY PHONE.NOT HOW UR CHARGING IIT.LOOKIT PUT YOUR BATTERY IN A PLASTIC BAG AND PUT IT IN THE FREEZER FOR ABOUT IDK 10 MIN
Anonymous
  • Posted on Feb 05, 2011
SOURCE: blackberry pearl flashing red light wont turn on
change your battery
When i plug my blackberry pearl in its charger nothing happens. It wont turn on or nothing.
try a secondary battery as well as a second charger (I believe the pearl uses micro USB, which is also used by bluetooth headsets, other phones, and pcs- you could even plug it into a pc with the cable to see if it charges)
If neither works, the phone is unfortunately dead. However if the battery works, bad battery. If the different charger works, bad charger
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
1helpful
My blackberry pearl wont charge
If it won't charge with the AC adapter, have you tried using the car charger? It may just be the adapter that doesn't work. You can also plug it into your computer with the USB cable and see if it will charge that way.
Blackberry plugged in to charge with a red light. wont turn on!
well take it back demand a refund my friends dad has the same thing he says that it SUCKS ON ICE
2answers
I dropped my black berry 8100 pearl and now it wont turn on, the red light will come on half way then full, but it still wont turn on.
This might be the Hardware issue you need to walk into the service center to check the hardware of your Handheld.
Thank you for using Fixya.
Wont turn on but red light is on
If it doesn't turn on, download the blackberry desktop manager & connect it to ur computer my phone wont stay on long enough to do this but it might work for you
My blackberry pearl turned itself off and when I tried turning it on all I get is an hourglass
  • BlackBerry Devices take a while to turn on, so be sure you have waited atleast 5 minutes for it to turn on
  • Make sure the battery isnt dead (plug in charger)
  • Try pulling out the battery and re-inserting it.
  • If none of the above steps worked, try this:
  1. Plug your BlackBerry into the computer.
  2. Download the latest version of the Blackberry operating system from your carrier.
  3. install it to your Blackberry using Desktop Manager
  • If it isn't recognized by the computer, or the install dosent work, call your carrier for a warranty repair.
2answers
Blackberry pearl 8130 flashed to cricket wont connect to internet
You can call cricket and ask them to "refresh" your internet, wait 5 minutes and try again. Worked for me.
2answers
Wont turn on
www.crackberry.com will help, just search in the forums for "recover a dead blackberry"
2answers
My blackberry pearl 8100 wont turn on
Try removing the Sim card and re-inserting it.
Grand Canyon Tech
Grand Canyon Tech
