SOURCE: Mitsubishi WD-62525 yellow blinking status light
Check that the lamp door is closed all the way. There is a saftey switch that closes from the door being on all the way. If not the status light will keep blinking. There is also a switch on the air filter door.
SOURCE: I just replaced a 915P026010
Is the Lamp Fan running ?As far as that goes is all Fans running and have you Pressed reset button?
SOURCE: I replaced the lamp in my Mitsubishi model
You may just need to reseat the lamp in the holder.
SOURCE: I recently replaced a 915P026010
Make sure lamp cover is also fixed on tv cabinet after lamp installation.
If lamp cover has not been put on its place, tv wont turn On due to safety switch inside that place that gets press with lamp cover.
Thanks.
Testimonial: "That was it! Thank you so much!"
SOURCE: error code 13 on mitsubishi wd52628
wait for the light to go out then press power. Then if it doesnt power up hold the menu and the Device/input buttons on the set both in together for 5 seconds the light will blink a series of blinks pause briefly then blink another number of blinks then pause then it will repeat the same two digit blink sequence a few times . Let me know the two digit blink sequence.
