Sometimes it happens right away and sometimes it happens when it's in the cycle of break making. Is it something related to bad power wire connection? or is it something that I can fix?
SOURCE: Intermittent Flashing 4x4 Light
This was a weakness of the Montero Sport models. If you google Montero Sport 4WD light flashing you will find lots of information. The best troubleshooting article I have found is here: http://4wd.blogeasy.com/article.view.run?articleID=318776 This article is about the Pajero, but the Montero Sport uses the same platform so this article applies.
The Montero Sport uses several switches and vacuum modules to put the system in and out of 4WD. If any of these malfunction, the light may flash continuously, flash intermittently, fail to come on, and it can trigger the anti-lock brake light to come on. In brief, if the 4WD shift lever is engaged, but the transfer case doesn't engage, the sensors show a mismatch and will cause the light to act funny including triggering the vehicle's anti-lock break light. These SUV's need to be shifted into 4WD regularly to keep the switches and mechanisms working correctly.
Try this before you even think about a visit to the $$$$$ Mitsubishi Dealer:
Shift the 4WD lever between 4WD High, Low and 2WD at least 100 times. Often, this will free the mechanisms and resolve the problem. It worked for me after three years of trying everything else including the dealer replacing switches, etc. If this does fix it for you, just be sure to shift the vehicle in and out of 4WD several times at least one a week and this will keep the mechanisms lubricated and functioning correctly. If that doesn't work, try the above link (article). Good luck!
Jeff
SOURCE: Car makes funny noise upon starting on very cold days
Have your power steering belt checked and adjusted, or replaced if worn.
SOURCE: abs light comes on and off randomly
sounds like an intermittant fault in the ABS control valve, most likely one of the solenoid valves is sticking or out of self test range..
SOURCE: Jeep Grand Cherokee power outlet
this outlet is like the cig lighter outlet and could be just burnt out and need replacing they do screw out. Becarefully the inside is shape.
SOURCE: My right indicator on my 1.2 T reg renault clio
hi, this sounds like you have a bad earth at the rear lights, remove both rear light clusters and check for any signs of corrosion, give all connections a clean and a little tweek, this should cure your problem
Reboot the breadmaker's electronics by pressing and holding down the Stop button down until you receive a visible and/or audible confirmation, usually within 1 to 5 seconds. Note: Some models require you press and hold the Start button instead. Others require you press and hold the Select button instead.
Hope This Helps!
I maintain a database of bread machine manuals. I have checked my files and I do have an electronic copy of your bread machine manual. I charge a small fee for the work that goes into finding, scanning, creating, maintaining and providing them. If you are interested email me at
As a" thank you" I will include an electronic copy of one my bread machine archived recipe books as another attachment to the email.
Be sure to show the maker and model # of your bread machine in the email so I know which one to send. I get many requests and I need to know which machine manual you need.
Thanks, and Happy Baking!
