Hi Karen,
Fixya promises a fix, but some things are broken and can't be fixed.
I suspect that is the case here.
Sounds like the water valve might be stuck open.
Or the battery contacts are bad, a wire is broken, the clock motor has worn out, the internal on-off switch has worn out, electrical short, a piece of plastic has broken, a rubber gasket is broken or twisted in the way, sediment or minerals have built up in the valve. Or a combination of factors above.
Leaving valve exposed to freezing temperatures will crack the plastic.
Clean the waterway with CLR calcium lime rust and see if problem is solved, but immersing valve in CLR solution will not be good for electrical components.
I have not read any internet post where somebody says they repaired a water timer after timer has gone bad. This is true for all brands. I am looking for that information, and actively seeking factual accounts.
Since many other people have problems with Gardena valves, add a comment
and say what you did to fix problem so everybody finding this link can
share your solution.
Open following link below for some Gardena resources, including link to parts.
I do not know what parts to suggest, nor do I believe part replacement will solve problem.
I can't find sellers of Gardena parts, and the Gardena contact-us page doesn't respond back as of right now, but things are continually changing and folks visiting this link can update the post with their solutions, and add links to sellers of parts that would be of value.
http://waterheatertimer.org/How-to-program-Gardena-C1060.htmlGenerally speaking, except for some timers from Intermatic, Paragon and Tork, there are no replacement parts for timers.
I am not sure what manufacturer makes the timer mechanism for Gardena.
http://waterheatertimer.org/Intermatic-trippers-and-parts.htmlUpvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
