I have synced device several times, and I have turned power off and on. Neither worked on restoring my book.
SOURCE: how do i read books by using the ''ebooks'' on coby 4gb mp605
it has to be in the text format... you might want to create a folder for your book and break it up into chapters, because as it is text it will not save your spot.
SOURCE: I want read ebook on alfatel h1 mobile
I too have searched for PDF readers for china mobile.
But couldnt.
So, I converted the PDF file into TXT from "A-PDF Text Extractor".
After converting, I copied the TXT file into the Memory Card and opened it from E Book reader in H1. And it worked well.
Hope you'll try this.
Thanks.
Best of luck.
Unfortunately Aluratek did copy hardware from Ectaco and did not software. It does not have license to support Cyrillic fonts, so can not support Russian, sorry
SOURCE: I have a Sylvania SMPK4230
The manual is available here SMPK4230 Manual
The instructions for the ebook capability are on page 16.
Ebooks in text format, that is files with a .txt suffix are mentioned as being supported.
You can copy .txt files onto the device just as you can copy music or video files.
The player will display print on the screen for reading when you access those files.
I personally download ebooks to my computer and copy the ones i want to read on the go to my media player.
Other ebook filetypes are.lit, .htm, epub, and .pdf among others, but there is no mention in the manual if these are supported.
There are ebook conversion programs that you can run on your computer to convert to a type you can use.
SOURCE: how do I download the KINDLE APPLICATION TO MY
make sure you are connected to the internet, then load the Market app, searh for kindle, or amazon, you should find it, then just download and setup.
