Lands Phones Logo
l
louann brauch Posted on Oct 18, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We had a power outage yesterday and several of the phones do not ring for incoming calls, what should we do.
Mike
Level 3:
  • Master 4,383 Answers
  • Posted on Oct 18, 2017
Mike
Master
Level 3:
Answers
4383
Questions
Helped
1261276
Points
17064
Like all electronics, try unplugging completely, for at least 45 seconds and then repower.
5 Related Answers
Anonymous
  • 52 Answers
  • Posted on Jul 17, 2008
SOURCE: my phone is not ringing on incoming calls
did u try removing the battery and reinserting after 2 min..
and if already tried,
then try dialing from oter phones, or check the assign tone in ur phone contact from which ur testing to be assigned with some ring tone...
Anonymous
  • Posted on Jan 08, 2009
SOURCE: no ring for some phones after power outage- dks 930 phones
Press feature key then dial #* password 000000 next, go to sets, hit show, hit next till ringing assingment is display hit show and change from n to y on line ringing assingment. do this for each set and line that need to ring.
Anonymous
  • 37 Answers
  • Posted on Apr 29, 2009
SOURCE: Disconnects incoming calls after one ring
The problem may be a short on your line. (Have the local Teleco check your line.) If you have other phones, you may want to check them for dial tone(DT) when this happens. If you have no DT, your cordless may be the problem...unplug, and let charge overnight. If problem continues, replace the battery in cordless, or discontinue use.
Anonymous
  • Posted on Dec 30, 2009
SOURCE: our incoming calls are not ringing?
wen i receive incoming calls there is no ring or message alert
consultel1
george peters
  • 860 Answers
  • Posted on Jan 12, 2010
SOURCE: Norstar Meridian M7100 incoming calls - no ringing tone
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear & ring
press the Chng key till it says appear only press next key (lower right arrow)
The display should say line 002: appear & ring
repeat the procedure the same as line 001 for the remaining ringing lines
press the release key when finished
Samsung Prostar 816
Did you try unplugging power cord for five minutes? often this fix the problem.
Restore incoming call rings after power outage AVAYA
If you have a Backup & Restore card you can manually restore the system. If not you will have to restore everything by manually including voicemail greetings and automated attendants.
After power outage incoming calls cause all lines to light up
If this is happening on the entire system, then make sure you have the number of lines programmed correctly. If this is correct you may have a bad processor card. If this is a happening on an extension only, then the port/card may be damaged I would temporarily move the extension to another port on a different card and see if the trouble follows. If it does you have an issue with the phone not the port/card.
Since power outage phone lines do not ring - only to receptionist
Your system lost its programming. It will need to be reprogrammed completely. The lines are ringing on the extensions where I voicemail is, unplug voicemail and at least lines will ring in correctly.
Comdial Executech 6414 won't ring
DX-80 Comdial After power outage only Phone # 1 rings, i turned off for 1 min but no luck, any ideas?
4helpful
Samsung Prostar 816
To change the ringing on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down enter #20 the screen should say MMC DISABLED
1) enter in 1 2 3 4 1 # (that enables programming)
2) enter in #62 the screen should say day ring assn
3) press the line you wish to program
4) press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
5) press # when finished with the line
6) repeat steps 2 through 5 for the remainder of the lines you wish to change
The code for hold recall is #52
enter in your hold recall time in sec. and in a 3 digit format. i.e. 30 seconds = 030 a minute and a half is 090 and so on.
it sounds like the memory battery on the main board is no longer working which means that it'll happen again.
Samsung Prostar 816
The battery is dead and will not maintain system programing after a power outage. If the battery is not replaced this problem will occur everytime the power goes out.
2answers
Privacy
What you are experiencing is loss of programming. Is this fixed? Could be the batteries need replacing....
1helpful
Phones won't ring
Your memory battery on your telephone system is bad. when power is lost , so is the programming. to fix this , you must go into system programming. From any phone, without picking up the handset. Press #20 Dial 12341, Press #. Press # again and dial 62, Press Line 1 and then press the button of each stn you want to ring ,( The display will show 1 if you press stn 1 and so on.) program each line the same way.
Top Lands Phones Experts
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
