It's obviously warning you of a probable service/temperature issue, Do not ignore it.
Consult your users manual to make sure some settings did not get changed. Check for proper closure of doors. Make sure condenser coils are kept clean. See users manual for location of coils
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
SOURCE: When I come home the
Could be warning you that the condenser coil is in need of cleaning. Under front by toe plate or in the back under fiber cover. Vacuum out all dust and make sure the air circulation fan is running when the compressor is in operation.
SOURCE: Kenmore elite refrigerator alarm keeps going off
you have to send model number,on some bottom mounts there is a metal striker on the door that hits the switches,sometime that gets bent back,all you have to do is readjust the striker by bending it if screws aren't loose but i don't know what kind of bottom mount you have
SOURCE: BMW 2004 745LI alarm Keeps going off randomly when
when the hood is "open"you cannot set the alarm so it will go off as it thinks someone is trying to steal it.make sure both catches are operating correctly,a bmw dealer will (should)do the job for nothing(goodwill)my wife always asks nicely......ours is a 1987 3 series coupe...with full dealer history.
SOURCE: The alarm beeper keeps beeping even though the
hi,
you can check a limit switch at its door. it is located usually at the door area inside.
maybe it is not working already or get stuck that is why it doesn't sense that the door is closed.
most of the time it is getting stuck and you can fix it by just pulling it out or other ways to do it.
hope that solves your problem.
Don't forget to rate me. Thanks...
Regards,
John
SOURCE: whirlpool fridge freezer alarm s20D RSB33AG-B
I have a whirlpool s20d tsb33-a/g which keeps defrosting itself or something is stopping it keeping cold on a daily basis, the alarm is going off and -- is on the display. Could any one tell me what its likely to be or tell me how to fix it please.
