SOURCE: kitchen aid dishwasher doesn't clean dishes in the top rack
Sounds like you have 1 of 2 problems. Either your pump is clogged or you need a bigger drain loop.
replace the top spray arm and it should work ok again
SOURCE: Kitchen Aid dishwasher - top shelf not getting dishes clean
Is the top sprayer clean and not clogged so that the water can flow through? The top may not be functioning properly.
SOURCE: kitchen aid dishwasher not cleaning dishes well.
sounds like you have a broken chopper. have you checked the chopper how far have you taken it apart? if the unit is put back together point all wash arms in the same direction turn the dishwasher on after it has started washing give it about 2-3 minutes open the door and see what wash arm is not moveing. if the upper wash arm is not moveing you need to check the chopper.
Testimonial: "THANKS SO MUCH. WE REALLY HATED WASHING THE DISHES BY HAND. THE CHOPPER HAD FALLEN OFF AND JUST NEEDED TO BE PUT BACK IN ITS PLACE."
SOURCE: Mine is a K5-A Hobart Kitchen Aid mixer and the
sounds like you need a new bowl lift cam, on the n-50 which is a hobart table-top model pull top off pedestle, you will see the cam you have to remove one cotter pin and remove one split pin install new cam reassemble
