What can I Do If I Forgot My Toshiba Laptop Password - iSeePassword
https://www.iseepassword.com/forgot-my-toshiba-laptop-password.html..or try this link.
Forgot my password on my Toshiba laptop Google Search
SOURCE: Forgot Bios password
you have to open it and find the BIOS battery, remove it for a few minutes. this does not always work but it's the first step
thanks for rating
SOURCE: How to break Toshiba SP4600 Laptop CMOS PASSWORD
reset the bios by unpluging to battery doesed work
this is the only working solution:
To reset the password of an old Toshiba, you can use KeyDisk. (cf my web page)
If this doesn't work, you can try to build the Toshiba Parallell loopback.
To make a simple device that you connect to your parallell port, a lot of
Toshiba computers remove the password when you boot it up.
The device, named "loopback" by some, could be made out of any
parallell wire with 25pins connectors (db25). You should connect
these pins: 1-5-10, 2-11, 3-17, 4-12, 6-16, 7-13, 8-14, 9-15, 18-25.
A db25 looks like:
1 13
_______
\_____/
SOURCE: toshiba satellite laptop 1405-S151 HDDDPassword lock
'flash your bios' Google "How to flash Toshiba Laptop Bios" and you should get your answer.
Genenerly it's just a start up hoding a button down (on the rear of your computer).
Chur.
SOURCE: forgot password for toshiba laptop model ps210e.can i unlock?
Restart your Laptop and press F8 as soon as logo displays and go to safe mode. There you will get a warning message and click on Yes. Then Press ALT+CTRL+DELETE and enter user name as Administrator and log in without entering password. It will log in. Normally Admin accounts does not have passwords. If its not working please revert. we will send the software to break the passwords.Hope this helps!
