SOURCE: USRobotics USR5461 - WiFi local network intermittently available and unable to connect
I've been having the same problem where even hard wiring to the router won't work. I called USR and they had me reset to factory defaults. Now three days later, the same behavior is happening. I reset to factory defaults and it works again but I don't know for how long. Maybe these things just wear out after a while...who know.
SOURCE: trying to connect my PSP to wifi but it says connection error
firstly check the wireless mode on your PSP - is it on or off
SOURCE: i cant seem to connect wifi onto my iphone
try forgetting the wifi connection and then try connecting to it again
SOURCE: wifi connection to BT Home Hub problems
Try this link http://www.productsandservices.bt.com/consumerProducts/displayTopic.do?topicId=27873&s_cid=con_FURL_gettingsetup/interference#tab4
I had the same problem. I tried everything I could think of but this is what eventually fixed my problem.
Hope it works for you
SOURCE: not able to connect wifi in my lapopo
In connecting through a wifi, there are two factors to consider. (1) Wireless Router broadcast and (2) Wireless Receiver.
Make sure that your network router is broadcasting wireless internet or wifi. Also, you have to know if you need a pass key or password in order to connect to the wireless network.
Now, given that there is a wifi spot, your laptop should automatically recognize the wifi broadcast and negotiate connection without your intervention. This will only happen IF AND ONLY IF your laptop has a wifi radio receiver and that it is TURNED ON. When it is turned ON, it will connect you immediately if the network has no pass key set. If there is, then you have to enter that key when you try to manually connect it. (Right click on wireless network icon on system tray. Then it should say: Wireless Network Available. Then Click CONNECT)
To turn your wifi radio receiver ON, slide a switch button to ON position depending on your laptop model. If you dont have that kind of switch, look for the wifi icon printed in the keyboard keys. In some laptop, it is in F2. Now Press FN+F2 to turn wifi radio receiever ON and OFF.
Hi Millie MALDONADO, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
What are you printing from a mobile phone - Android
or an apple mobile phone ?
Did you download the mobile phone application ?
Do you have user guide ?
Check page 30 - 32 ofhttp://gdlp01.c-wss.com/gds/1/0300014431...
May be a little bit different but you are going to need the printers SSID name and the Password .
