SOURCE: Print Width Issue
the issue you are having is DPI related, when data is sent to the printer and rendered it is dot for dot, so a Z4M 203dpi printer has about 800dots on the printhead where your printer has about 1200dots on the printhead. so when your software prints to dot800 thinking it is the edge of the label it is infact at 60%. there sould be an option in the software to configure around this. if not the is an option in the printer to convert DPI setting ie 150>300 or 100>200 and so on. but i don't thing you can make a 300dpi print as 203dpi
best of luck
SOURCE: Zebra Z4MPlus doesnt communicate with PC
Ok,
This machine has a parallel port. Try to print via parallel cable. If it works, consider staying with it. Serial ports are a pain to manage.
If you absolutely have to do it via rs232 though....
Question 1. Has it ever printed?
If yes, Go into Windows Printers and Faxes control and select the Zebra or whatever printer that you are using. Right click on it and you should get a menu that at the bottom say "Properties", select that, then you should get a new window with tabs at the top. You want the tab for "Ports". Select it and you will see all of the different output ports that you can direct your printing. RS232 is a COM port. So start at COM1, check it and try to print. If that doesn't work, go to COM2, etc.
Last resort, If you can't get control via the printer driver program, you
will have to try redirecting the print manually (now you will
understand why I said to stay with parallel output).
What you have to do is redirect your printing via the dos "mode" command.
Under "Start Menu" goto "Run" and put in "CMD" and click "OK".
This opens a black square window with a cursor blinking. Type in this:
mode com1:9600,n,8,1 (enter)
mode lpt2=com1 (enter)
Tell your program to use LPT2 if you can and see if it works.
By now a parallel cable instead of RS232 should be looking really good.
SOURCE: Zebra 105 SE Printing Blank Labels
Seagull Scientific has drivers. Their Zebra driver is recommended by many.
http://www.seagullscientific.com/aspx/drvrmain.aspx
That's the link for their printer drivers page. Go to the bottom and click on 'Download a printer driver'. Then scroll the list to find the one you need.
SOURCE: Zebra LP2844 printer prints garbage
Sounds like you might be using a bad driver, or the printer is in dump mode.
Try hitting the green button and see if it says exiting dump.
If still having trouble, inside the printer it tells you that if you are having printing trouble:
This process re-reads the label length (so only do it with the labels you want to use in, or it will waste labels until you do it again with those in it) - but I'm suggesting it only because it enters and exits dump mode (which I have read can cause the garbage when you try to print).
SOURCE: An extra, blank label prints from a Zebra 2746e.
Check media settings in the printer driver. Check version of printer driver. Zebra printersuse an internal printer driver with their Zebra Designer software (Zdesigner driver) or a ZUD (Zebra Universal Driver) for other windows applications. These drivers can be downloaded directly from the zebra website.
Alternatively you can download the seagull scientific driver and use that instead. (used with bartender program)
Label skipping occurs if the media dimensions are not specified correctly. The important ones are label height, and media setting for type of media.
Perform a media calibration before you go changing settings. Power on printer, Hold top and bottom buttons in on control panel for 5 seconds, release bottom button only then when printer starts feeding labels release top button. When printer finishes press feed button.
