Make sure your rinse wash arms have the end plugs. If one is missing, water will spray out door.
Your fill valve could possibly be malfunctioning, therefore not closing all of the way. I used to work for Hobart. These LX machines can be a pain in the rear. If you have a water softner, then the valve is probably functioning normally. I do not recall it ever being the door gaskets. I would think you should be getting an error code with the wrench. This is a hot water machine. If you have lime scale building up inside, you may try deliming it. The drain valve could be also causing a problem. There are so many things it could be.
SOURCE: Fisher and paykel 913T soft touch dishwasher leaking
I had the same problem and replaced the door seal. You need to remove the front door to do this. Requires some 'handyman' experience.
SOURCE: dishwasher door leak
Hi
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Also,The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem.
If the latch has worn out in a way that makes it impossible for you to close the door properly, you probably need to replace the latch.
A Fixya rating would be appreciated if you have found this solution Helpful.
Thanks
Rylee
SOURCE: door still leaks after replacing bottom seal
the bottom seal isn't actually a seal, rather it serves as a splashguard. I had the same problem with the same model and started by replacing what I thought was a seal located at the bottom of the door.
Check if the screws on the top half of the pump (located under the lower spray arm which needs removed first) have become loose. The screws were barely in the threads which caused a stream of water towards the door and leaked between the splashguard and bottom edge of the tub and onto the floor.
SOURCE: door of dishwasher is leaking at bottom left corner.
HI. the door seal has been compromised. it could be simply farad or slightly propped open by some sort of debris as well. check the door seal for faults. replace if faults are found.
Also, make sure the door isn't mis-aligned. this will happen over time during heavy usage. re align the door if necessary.
SOURCE: water leaking from door
your drain is clogged. if ice isbuilt up in the freezeer floor. when the freezer defrosts and the drain is clogged it has no where else to go other than ouot the front. pull everything out of the freezer and check twards the rear at the bottom. remove as much ice as possibile let set unplugged and door open for 3 hours. then take a cup of boiling water and pour it back there. if it dont drain repeat that process with the water-have a towel ready because if the water stays back there long enough it will get cold. you need to keep the water HOT. ice could be built up in the drain. hope this helps
Not only can missing end plugs cause water to come out door, but having debris inside of the arms can cause this to happen also.
