SOURCE: My GE Oven heating element and timer clock went
Try unplugging the oven and let sit for 10 min. This will reset the curcuit board and reboot the electronics. You may have to pull out the stove o get to the cord.
SOURCE: Keypad/clock went blank
Normally when a power surge lands a direct hit on a non protected circuit board, it will usually fry it completely. you can confirm this by shutting down the power for 5 minutes. if the control doesn't respond after the 5 minutes of no power, this will confirm circuit failure due to the surge and, you will need to replace the board in this case.
SOURCE: I have a built in electric oven and yesterday the
find the main breaker for the oven turn it off for about a minute and then turn it back on ...yep some times you have to reboot even your oven
Good Luck
SOURCE: electric stoves
Most stoves you must set the clock before the oven will work.I know sounds stupid...
