Holds programming data Won't hold main time or date Keeps defaulting to 01/01/01 and reset time.
SOURCE: pc date keeps resetting to 01/01/2001
I can only presume thsi is an older handhels.
There is a small CMOS battery that has run out.
It may be a Dell only fix.
On a PC it is on the M/board.
Small flat battery like in a watch.
Take it out and get a new one from local watch shop or Jewellers or PC shop.
SOURCE: Sharp Electronic Organizer Model ZQ-5200 how do I reset the date
I just ran across my manual. My organizer died, but here goes. You have to set the home date and time as the city's date and time for your time zone. Press Shift-Home. Select 1 to choose the City. Cities are listed according to their country. Press U for United States. Press the up or down arrow to scroll. When you see your City or one in the same time zone, input that number. If DST in effect, press shift-number for the city. To set time, select 2,or Shift-Home-2. Set the time. Press enter. Good Luck.
SOURCE: my solar clock needs setting. I set it back an
1) Pull the batteries and replace them, or gently insert a straightened
paper clip into the "reset" hole in the back of the clock. The clock
will beep.
2) Press the "receive" button" so the clock sets itself. The default time zone will be "EA".
3) Press the "adjust" button untill the time zone is showing (rather than the day-of-the-week).
4) Press and HOLD the "set" button down untill the hours digits start to flash.
5) Now press the "set" button again six times. The time zone characters will flash.
6) Press the "adjust" button untill your time zone appears.
7) Press the "mode" button to return the clock to normal operation.
8) Press the "adjust" button to display the day-of-week.
SOURCE: I have a 1F81-51 White-Rodgers thermostat that
I had the exact same problem. Even pressing the Hold button does not really help, because once it resets - the Hold temperature also changes to the default.
I fixed this by replacing the 470 micro-Farad / 10v capacitor in the unit (it's the grey-colored capacitor). To access the back of the circuit board, you will need to break 2 plastic rivets holding the front of the unit to the base.
After replacing the capacitor I've not had any resets for the past 3 days (it used to reset itself every couple of hours).
Hope this helps.
Noel
SOURCE: My Stoves 720EF Heritage oven keeps turning itself
does anyone know were i can get a replacement top oven inner glass for my stoves heritage 720EF ?
