Model #284325009 SN #WB322064279
**Freezing gas may have leaked out at some point. Compressor works but freezer not freezing.
**Thermostat setting not suitable for freezing to occur; check and adjust
**Check whether evaporator at the back of your freezer is hot/slightly warm to touch. If it's not; call your freezer service/repair man asap
SOURCE: Kenmore® (46-26072) Elite® 20.6-Cu. Ft. Frost-Free White Upright Freezer
Check these two things first. 1. Is there a thick frost buildup on the back panel at the bottom half of the freezer? 2. Do you hear the fan running inside the freezer? Let me know what you find.
SOURCE: Freezer won't run
There is no reset switch. There is a thermal overload protector mounted on the compressor. Does the compressor hum and then give a click sound. If so your compressor has failed. If the compressor is cold (Room Temperature) and it does not try to run your thermostat may be bad. If so remove the temperature control and jumper the two main wires that connect to the control. Unit should be unplugged to do this operation. Insulated the wires so they do not contact any metal surface. Plug the freezer back in. If it runs and cools replace the thermostat.
SOURCE: problem with upright freezer not freezing
It sounds like the unit is low on freon or the compressor is going bad. You have several other components that could be affecting this as well. Make sure the coils are free from dust and clean underneath. This is a bit premature for you to have problems now, especially since it is a Sears product.
SOURCE: Kenmore Model 116 upright beltless vacuum, agitator will not turn
I had the same problem. The agitator stopped turning after I sucked up a foreign object (my wife's watch) and it got jammed in the intake. After removal of the watch the agitator did not spin when turning on the machine, and the reset button never deployed (it remained buried in its housing and would not depress with a paper clip). The agitator was not bound and I could manually move it in both directions with ease. Faced with prospect of paying $125 or more for a repair, a good sharp kick to the chassis from the top promptly fixed the problem. I have found that kicking malfunctioning electronics often works.
SOURCE: Sears Ken Elite upright freezer model no 25329082991 temp alarm
alarm should go off when freezer reaches minus 18c or lower.
