Cars & Trucks Logo
Phil Sheffield Posted on Oct 12, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Po306code? rough idle hard shifting
Darryl MacDonald
Level 1:
New Friend:
  • Contributor 24 Answers
  • Posted on Oct 12, 2017
Darryl MacDonald
Contributor
Level 1:
New Friend:
Answers
24
Questions
0
Helped
13464
Points
93
A P0306 code indicates a misfire on the number 6 cylinder.
P0300 means a misfire on multiple cylinders, P0301 is misfire cylinder 1, P0302 is a misfire cylinder 2, etc.
I'm not sure what kind of vehicle you have, but something is causing a misfire on cylinder 6- could be a bad spark plug, ignition coil, fuel injector.
So you should be looking for something that relates only to cyl 6 and not the other cylinders. A fuel filter feeds all of the cylinders, so it would not just cause a misfire on one cylinder, for example.
Good luck!!!
Rick M
Level 3:
  • Cars & Trucks Master 4,148 Answers
Rick M
Level 3:
Answers
4148
Questions
0
Helped
1254629
Points
13941
Misfire in cylinder #6. Could be bad spark plug, spark plug wire, cop coil, bad intake/exhaust valve, clogged fuel injector or piston/cylinder problem. What's the year, make, model, engine and have you been following the recommended maintenance schedule for new plugs?
2004 jeep cherokee overland when shifting from park to drive loud noise and idle is running rough
find noise location first. never ignore noise on machines. and 10x that on man movers. 100x that in the air.
then scan it. using any obd2 scan tool,
a tool that does Jeep factory codes. 10x that.
Rough idle loss power
I think the hard shifting is due to a faulty transmission control selonoid. As for the code p0102, looks like the mech, only changed what the code refered to , and not your actuall problem. I suspect a loose or broken connector or vacuum hose leak. A simple vacuum leak can throw all sorts of codes. Usually with very troublesome problems that are hard to find, most times a good option is to take it to your gmc/chevy dealer and have their team have a crack at it.
Will not idle when cold
Its cold start issues:----
Go through the list of help links mentioned below:----
Click the link :----
Cold start problem and vehicle shudder around 2500 to 3500 rpms
http://repairhelpcenter.blogspot.com/2012/10/cold-start-problem-and-vehicle-shudder.html
Low idle when cold out side?
http://repairhelpcenter.blogspot.com/2011/12/low-idle-when-cold-out-side.html
Ford explorer 4.0 will not idle when cold?
http://technoanswers.blogspot.in/2012/02/ford-explorer-40-will-not-idle-when.html
Automatic transmission shift lever hard to move on cold mornings?
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
Car won't start when cold?
http://schematicsdiagram.blogspot.com/2011/12/car-wont-start-when-cold.html
It can be issue with IAC( idle air control valve) causing the problem.
There are many other possibilities causing these idle issues. Engine idles rough.
There are few help links with solutions to troubleshoot such idle issues.
I suggest you refer the link below and follow its troubleshooting details:------
Click the link below:-----
Ford Expedition IAC valve replacing
http://technoanswers.blogspot.com/2012/12/ford-expedition-iac-valve-replacing.html
Bad miss at idle?
http://technoanswers.blogspot.com/2012/01/bad-miss-at-idle.html
Stumbling and stalling at idle after engine rebuild?
http://schematicsdiagram.blogspot.in/2012/03/stumbling-and-stalling-at-idle-after.html
1999 Ford F-150 Idles rough and quits when gas pedal is pressed less?
http://technoanswers.blogspot.in/2012/01/1999-ford-f-150-idles-rough-and-quits.html
Engine stumbles coming off idle when warm?
http://repairhelpcenter.blogspot.com/2012/01/engine-stumbles-coming-off-idle-when.html
Erratic idle on car?
http://schematicsdiagram.blogspot.com/2011/12/erratic-idle-on-car.html
GMC Sonoma Stalls and idles low
http://technoanswers.blogspot.com/2012/10/gmc-sonoma-stalls-and-idles-low.html
GMC Idle Air Control (IAC) Valve Replacing?
http://schematicsdiagram.blogspot.com/2011/12/gmc-idle-air-control-iac-valve.html
1996 Camry intermittent engine failure while idle?
http://repairhelpcenter.blogspot.com/2011/10/1996-camry-intermittent-engine-failure.html
Engine quits at idle?
http://repairhelpcenter.blogspot.com/2011/10/engine-quits-at-idle.html
Car overheats and Air blows hot at idle?
http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
High Idle Problem
http://repairhelpcenter.blogspot.com/2012/10/high-idle-problem.html
While stop engine idles like cylinder missing?
http://schematicsdiagram.blogspot.com/2012/01/while-stop-engine-idles-like-cylinder.html
Idle flair is noticed on car? Rough idle? car will not idle? Erratic idle speed?
http://technoanswers.blogspot.in/2012/02/idle-flair-is-noticed-on-car-rough-idle.html
High rpm in neutral? Inconsistant high RPM in neutral?
http://technoanswers.blogspot.in/2012/02/high-rpm-in-neutral-inconsistant-high.html
Vehicle stumbling at idle and shows code 54?
http://schematicsdiagram.blogspot.in/2012/03/vehicle-stumbling-at-idle-and-shows.html
Rough idle, staling and Erratic shifting?
http://technoanswers.blogspot.in/2012/03/rough-idlestaling-and-erratic-shifting.html
These details will help.
Thanks.
My Chevy 2500, 2001 runs rough when it cold outside
It can be issue with low fuel pressure,the fuel pump is getting old both needs to be checked.Also get the IAC valve checked.
Go through the related help links with similar problem,it may help:---
Click the links below:---
Engine Idles Rough and Dies? http://whatisbyme.blogspot.in/2012/05/1994-lexus-es300-engine-idles-rough-and.html
van idles rough? http://howtobyme.blogspot.in/2012/01/2004-ford-freestar-van-idles-rough.html
runs lean and idles rough? http://technoanswers.blogspot.in/2012/02/ford-runs-lean-and-idles-rough.html
Car still runs Rough after tune up?
http://howtobyme.blogspot.com/2011/12/car-still-runs-rough-after-tune-up.html
2006 kia rio runs rough http://technoanswers.blogspot.com/2012/10/2006-kia-rio-runs-rough.html
Idle flair is noticed on car? Rough idle? car will not idle? Erratic idle speed? http://technoanswers.blogspot.in/2012/02/idle-flair-is-noticed-on-car-rough-idle.html
Rough idle, staling and Erratic shifting? http://technoanswers.blogspot.in/2012/03/rough-idlestaling-and-erratic-shifting.html
Thanks.
My 1998 Volkswagen Beetle keeps dying.
With the car running rough it could cause the harsh shift but if it is staying at 5000 rpms then the ****** is about to go out on you. The rough idle sounds like a vacuum leak. If you can keep the car running at idle listen for a sucking type sound. That would indicate where the vacuum leak is.
2helpful
92 NISSAN WITH BOGGING AT 2800 3500 RPM AND AT LEVEL SPEED 4CYL AND 5 SPEED
For this types of problem,there are few help inks to troubleshoot the problem.Click the link below to go through the troubleshooting procedure to resolve the issues :----Idles rough and quits when gas pedal is pressed less? http://technoanswers.blogspot.in/2012/01/1999-ford-f-150-idles-rough-and-quits.html-----------van idles rough? http://howtobyme.blogspot.in/2012/01/2004-ford-freestar-van-idles-rough.html
--------------runs lean and idles rough? http://technoanswers.blogspot.in/2012/02/ford-runs-lean-and-idles-rough.html
-----------Car still runs Rough after tune up? http://howtobyme.blogspot.com/2011/12/car-still-runs-rough-after-tune-up.html
------------Idle flair is noticed on car? Rough idle? car will not idle? Erratic idle speed? http://technoanswers.blogspot.in/2012/02/idle-flair-is-noticed-on-car-rough-idle.html
----------High rpm in neutral? Inconsistant high RPM in neutral? http://technoanswers.blogspot.in/2012/02/high-rpm-in-neutral-inconsistant-high.html
------------Engine Backfires? http://technoanswers.blogspot.in/2012/02/jeep-backfires.html----------- Nissan stalls and bucks on Acceleration?
http://technoanswers.blogspot.in/2012/02/nissan-pathfinder-stalls-and-bucks-on.html
Nissan Pathfinder Backfires? http://technoanswers.blogspot.in/2012/02/nissan-pathfinder-backfires.html
---------How to adjust rpm? http://schematicsdiagram.blogspot.com/2011/12/how-to-adjust-rpm-on-2009-dodge-charger.html
------------Engine cuts out at 3000 RPM? http://schematicsdiagram.blogspot.com/2011/12/engine-cuts-out-at-3000-rpm.html
----------This will help.Thanks.
4helpful
2answers
1helpful
2answers
Hard down shift
sounds like your transmission. also it could be the axle, which if it is, consider yourself lucky. you should get it checked out.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
