SOURCE: Ipod won't turn on 3rd generation silver
Has the battery been charged lately? If not, try charging it first and then try to turn it on. If that is not the case your ipod probably just needs to be reset. Try pressing the center button with the menu button together and hold those two buttons together for about 6-10 seconds. You should get an apple icon that comes on before you will see your menu for your applications.
SOURCE: IPOD CLASSIC FLASHING APPLE LOGO AND WILL NOT CHARGE PLUS WILL NO
The flashing Apple is the equivalent of Microsofts blue screen of death. This apple symbol means hardware failure. Not good. Do a Google search for flashing apple of death. Here's a video that should help you fix it yourself. Hope this helped.
http://cnettv.cnet.com/2001-1_53-25928.html
SOURCE: My iPod 160 GB Classic is stuck with just Apple
Try forcing the iPod into disc mode to restore.
Putting ipod into disc mode
http://support.apple.com/kb/HT1363
Toggle the Hold switch on and off.
(Set it to Hold, then turn it off again.)
Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect"
If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
If this does not make the iPod connect to your computer, I would suggest checking out www.rapidrepair.com for further ideas and options to your issue.
SOURCE: how can i reset my apple ipod classic?
This link to the apple support site will help you
http://support.apple.com/kb/HT1320
SOURCE: My ipod classic blinks after it got wet. The apple
my apple ipod classic is not working but a apple blinking on the iposd screen reaptelly.how its proplem ?
