Question about Bosch Washing Machines
My Bosch maxx7 is not heating the water on all programmes , it also stays on 1 minutes until you put it to spin manually then it finished the programmes
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 121 Answers
The heating element has gone faulty
Posted on Oct 11, 2017
Anonymous
SOURCE:
Anonymous
  • 3 Answers
SOURCE: very annoying beep when finished programme
When the machine is on, but not running, press and hold the "pre-wash" button. After a few seconds it will begin that beep noise, keep holding it in until the beep volume goes down and finally stops completely (5-10 secs). Once the beep has stopped, release the button and voila, no more annoying beeps at the end of your cycle.
To restore the end of cycle notification (beep) do the same thing as described above, but release the button earlier while the beep is still going.
Posted on Dec 06, 2008
jonniewalker
Starnley Johnwells
  • 1031 Answers
SOURCE: F17 Fault on Bosch WDV24520
If you open the washing machine you will find a packing slip with all the information on the error codes and electrical schematic. F17- covers the following problems - supply hose kinked/jammed, clean filter, water pressure too low..hope this helps
Posted on Mar 14, 2009
Anonymous
SOURCE: bosch classixx 1200 washing machine stalling mid-cycle
I`ve just spoken with Bosch Product Advice service about this problem. This could be happen when door is open after programme has been started. I didn`t check yet is working.
Thanks, roman
Posted on Jun 04, 2009
Anonymous
SOURCE: bosch exxcel wf02465 wont spin
We had similar problem, with the spin cycle not working. We opened the 'drain' pipe (front-right bottom side). It was full of lime scale; never been opened for years. We cleaned it up and the spin cycle is now working.
Posted on Sep 13, 2009
prem mathew
  • 662 Answers
SOURCE: mACHINE STICKS WHEN SPIN PROGRAMME REACHED
The 03 error code is the drain. Disconnect the drain hoses and check for blockages. If no blockage "time" the drain interval. If it's more than 6 minutes it's the pump. Also make sure you're using the correct type of soap so the ball check valve on the bottom of the outer drum isn't getting fouled with excessive suds. Also disconnect the drain hose from your house plumbing and let it free flow on it's own. This will tell you if the block is in your plumbing, and not in the machine. Assuming that your filter is clean.
Pl rate me ‘very helpful’ for the free help!
Posted on Jun 15, 2010
The plug of my Bosch Maxx7 melted and also the lead. I put a new plug etc on and the spinn light keep flashing and tried to reset the machine but it wont come on.
Most likely, the main control board of the washing machine was damaged by the power surge that melted the plug. Additional wiring damage may have also occurred. The damaged electrical parts will have to be replaced.
Please add a comment with the model number of your washer if you'd like a parts diagram and price list for your machine. The parts diagram for one Bosch Maxx7 model, WAE28490GB,
is available here: http://www.bosch-home.co.uk/customer-service/care-protection-and-parts/WAE28490GB/01#/TabsTogglebox=spare-section-3/ . See diagram 1/5.
Your homeowner's insurance may pay for the damage, under some circumstances. It isn't covered by the Bosch warranty.
May 07, 2018 | Bosch Washing Machines
My belling washing machine doorv wont open
from the factory info,,,
door lock is activated because of the water level in the machine.
Drain the water by running the Pump or Spin programme.
• Machine is heating up the water or it is at the spinning cycle.
Wait until the programme completes.
• Child lock is engaged. Door lock will be deactivated a couple of minutes after the programme has come to an end.
Wait for a couple of minutes.
when in doubt unplug for 5 minutes and plug back in and see if that resets the unit.
Hope this helps a little.
Jan 09, 2018 | Belling Washing Machines
Bosch Tassimo TAS4513UC 1-Cup Coffee Maker manual
I looked up your problem and found the same one was answered previously on fixya. I have copied and pasted the previous answer here for you. Good luck and I hope you have a great day!
After many months, I solved the problem of the red light staying on the Tassimo Coffee Maker. Use these easy steps.
1. Fill a 2 cup measuring cup with hot water.
2. Mix in descaler.
3. Pour in the empty water tank.
4. Put the yellow cleaning disk in the chamber and close chamber. Put the two cup measuring cup under the spout.
5. Push and hold the brew button for about 3 seconds (until the red and green light flash.
6. Now don't touch the machine. It will do it's thing for about 20 minutes. (Don't be impatient and start to push buttons, just leave it)
7. When it finishes it's cycle. The red light will turn off. Then clean the water tank and put fresh water and run clean water through the brewing cycle 4 times. Your machine is now ready for use.
Mar 25, 2014 | Bosch Tassimo TAS4513UC 1-Cup Coffee Maker
Hi I have model No WF 740 1400 spin! However programme L is filling up with water, appears to be washing as normal until it reaches final 7 minutes, then machine becomes laboured and will not spin! the...
it appears that the pump is not removing the water that is spun out  if there is a belt on the pump then it may have fallen off or need replacing   if it is intact then the pump either failed or there is a blockage in the line
Nov 08, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Bosch exxcel multi programme ....programme gets to 1 min and then stays there. on the quick cycle on the auto cycle it gets to 60 min then returnsto 140min on the timer... thankyou
this is caused by incorrect water levels the appliance takes in too little water at final rinse and generates erro code 1 this is what you are getting it isnt 1 minute to go it will need the dishwasher equivalent of colonic irrigation several tubes will be full of fatty deposits,using the quick wash a lot will make this happen more often you will need an engineer to sort but shouldnt need any parts.
Aug 06, 2009 | Bosch Dishwashers
Bosch exxcel programme runs until 1 min left and won't finish
This is a fault code which indicates it has not heated through the programme
Dec 13, 2008 | Bosch 24 in. SGS43C12 Classixx...
Bosh 1200 classixx does not finish the program, conditioner stays in the dispenser
I have cleaned the pipes going for rinsed water,plus the plumbing stuff like vertical pipe which has on top something like coupler for washing machine and dishwasher, here was problem. It was cloged up with rubish and becouse the pump could not make enugh pressure the machine has stopped in the moiddle of washing as it could not rinse.(Spin)
cheers
Sep 23, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Washing Machines Logo
93 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
peter gittos
peter gittos
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
