SOURCE: Alpine car cd player has no volume
It's possible that you have a shorted speaker wire. If one of the speaker wires is pinched, grounded or shorted it will cause the deck's internal amplifier to shut down. The easiest way to check is with a multimeter's resistance function. Remove the CD player and unplug it. Set your multimeter for "resistance" or "continuity". Attach the black probe to chassis ground; you can use the black ground wire in the deck's harness, clean dash metal, or the outer ring of your cigarette lighter. Use the red probe to test each of the speaker outputs in the harness: white, gray, green and violet. If you find a speaker wire that shows any continuity with chassis ground, then that's the cause of the problem. A speaker with a damaged voice coil may also cause the deck to shut down. To test this, probe the positive and negative leads of each speaker and test the resistance between them. For example, to test the left front speaker you'd put the red probe on the white wire and the black probe on the white/black wire. Each speaker should read a minimum of 3 ohms of resistance. If you get a lower reading then it might be causing your problem. If you don't find a problem with any of the speaker wires, then chances are the deck's internal amplifier has failed.
SOURCE: heating up on back of cde 9852 alpine cd player
try to chek the regulator or replace it and install a heatsink for him
SOURCE: Alpine CDA-7873 (Same as CDA-7876 basically)
the blue line from the radio harness does not have power when the cd or aux are being used and the amp is not turning on-wire the remote line from the amp to the red line and your amp will stay on and you will get sound
SOURCE: radio sound but NO cd or ipod sound
its not the radio. you have an amplified system in your vehicle and you hooked up the power antenna (blue wire from the radio) and the amp is only energized during AM/FM playback. disconnect the blue wire and connect the blue/white to the car's harness to energize the amp during ipod and cd playback
SOURCE: Road Tech? HA90 MP3/WMA? Digital Music Player
My husband hooked one up with Kuryakyn speakers (amplified). BUT - we CANNOT get the music on the card...Windows seems to not like the idea of synch-ing without folders and the MP3 player cannot read folders... I'm pulling my hair out over this!!!!
